The vibration argument is not about the wheel face to hub face angle not being coplanar. The angle between them (within realistic reasoning due to tolerancing) is basically zero when you tighten the
f@$Ken bolts. The reason why factory wheels do not use hubcentric rings is because factory wheels have the bore sized to fit the hub pilot.
Aftermarket wheels are a different story!! They usually have ONE bore size and then use the rings to fit them to each car within that wheels bolt pattern family with subsequently smaller hub pilot diamters.
Just because some dufus wrote a web page doesn't mean he can make something gospel. You can try and refute engineering design rules all you want, but it doesn't mean squat. If your so called theory was true then hub faces could be pefrectly flat with no piloting button whatsoever. Damn, this means every car manufacturer out there is wasting billions of dollars machining this feature in. You should patent it and become a millionaire!
![](/ubbthreads/images/graemlins/rolleyes.gif)
Like I said before, it works like this:
Hub pilot and wheel bore center the wheel to the hub
Lugs provide the clamp force between the wheel back face and the hub
The friction between the wheel back-face and the hub face carry the load. NOT THE LUGS AND NOT THE RINGS.
End of story.
[Monty Python] Bring me another moron, this one's brain exploded![/Monty Python]
