#121384 07/18/02 11:04 AM
Now that my exhaust mod was a success, I want to modify the intake system. I live on Long Island and it gets warm here so heat soak might be a problem. Furthermore, what will happen to the intake teperature sensor that is currently in my stock air box?
KKM?
SHO Shop?
How about BAT system?
Any suggestions ?
Thanks!
2000 Stique
V6 - 5 speed
Fast with class!
#121385 07/18/02 03:04 PM
I would say to use any Open Air filter, you'll notice a good improvement. Im sure this is the part where everyone yells out "KKM". Whatever...
Buy the braket from Mirko that fits a filter on the stock Mass Air Sensor.
I currently have a Cold Air Intake setup, which again everyone yells out "Heatsoak". But what do I know.
(Check out my webpage below)
ALSO YOU THE SEARCH TOOL- You'll find alot of useful information there.
Silver 98 SVT Contour E0
#4124 (Currently on Life Support)
Built 11/97 Bought 1/98
Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods
Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI
"Come Out...Come Out Where Ever You Are"
http://www.geocities.com/speeddemons19
#121386 07/18/02 04:15 PM
The IAT sensor is relocated to plug into the accordian tube with some of the kits out there. (Between the MAF & TB is really a better location.) There are some great gains to be made from opening the intake, and the bigger the better! Go for the BIGGEST opening you can fit on the air filter and MAF adaptor. The S&B "Big Mouth" cones will flow well. You may want to customize/optimize a standard MAF adaptor to get the most air into the engine. The accordian tube is worth replacing with a smooth pipe. (Many posts on new products out there...)
Scott
