Page 2 of 2 1 2
H
H
The 6" does scrap a little on driveways. I just back out of them at an angle. And this works everytime. Mine is center/center, so the flow is real good.
I think that the could use a 2.5" inlet muffler on a 2.25" pipe.
98 T-Red Contour LX V6 Mtx 106k miles
9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
these mufflers are only 3 5/8" high, i was concered about width inside the exhaust tunnel
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
A Magnaflow 5x8 fits perfect. I can get you one if you want in 2.25" in offset/offset, even though center/offest is the correct setup, IMHO. I know, I have supplied three of them, in that configuration, to CEGer's already and they said that they all fit perfect.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
it could be the center/offset is different on the magnaflow vs. edelbrock, center/offset on the 5503 is off by about 1.5 inches...
i'll try the muffler shop to see if it will fit - if not, i'll see if the guy will trade me a Magnaflow smile
Page 2 of 2 1 2
