#121190 07/12/02 03:53 PM
E
E Offline OP
E
i was laying in bed last night thinking about what else i could do to my contour...i got to thinking about the air intake temp sensor. what effect would it have on engine performance if the sensor thought the air was colder than it actually is, or vice versa. If fooling it into sensing colder air is a good thing then any suggestions on how that can be accomplished?
95 Contour GL Zetec
New 16" Focus wheels! (look better on contours!)
APC Plasma white high and low beams w/ upgraded wiring harness
Pilot Hyper white fog lights
Cold air intake
Optima battery
APC billet antenna
Sony Cd Player w/ jensen subs
Green neon pedals
Green strobes for reverse lights
Ventvisors
20% mirror tint all around
Custom grille
Aftermarket keyless entry
Remote car starter (very usefull)
#121191 07/13/02 12:56 AM
Z
Z
it has been done with the Zetec on ther ZX2 not sure if anyone on CEG has done it to me though the performance gains are iffy one person would claim large performance gains and then another would say it didn't do a thing and then another would say it caused a CEL. me I just wouldn't mess with it.
here is a link to a ZX2 site showing you how to do the mod.
hope this helps wink
Joe Hartley
"yes I know it's a MTX Zetec but it beats having a ATX Duratec"
Champagne 96 GL MTX some mods
dynoed at 114.2whp and 124.4wtq (pre CTA intake)
16.858 @ 80.76mph (yes it's slow but still faster than D Davis)
AIM: ZetecRacing
My Site My Profile
#121192 07/15/02 03:13 AM
Try a search for "resistor" in the performance forum. This has been discussed quite a bit. A single resistor in series with the sensor will effectively fool the computer into thinking the intake air is cooler. Just cut one of the wires going to the sensor, and splice in a 1/2W resistor. You'll want between 2 & 10K ohms of resistance. Put some push connectors on the wires so you can experiment with different resistor sizes and see what happens. Some say it helps, others say it aggravates pinging. frown
Scott
#121193 07/15/02 04:11 AM
So basically that mod allows you to run higher octane and if you don't then car goes boom. I was looking at haynes manual and it shows the ECM as having a connection for Ford to change what octane gas your car uses. So maybe you could get Ford to change your car's set octane.
"Wow, that sank fast." "Yeah, like a rock."
96 Contour GL ATX
9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned
Sony CD player: 50wattsx4;remote;
Speakers=50 watt Pioneer 6x8s
Ross Evans smile
#121194 07/15/02 05:19 AM
Z
Z
no need for him to search if he wants to do it I gave a link to a nice how to....
Joe Hartley
AIM: ZetecRacing
My Site My Profile
