Posts: 107 |
Car has 73,000 mi is ready for its first rotors & pads. What is the feeling about drainig the break fluid with this service. I don't work on the car myself so this will cost an extra $67.
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
If it were my car, I wouldn't hesitate at all; do it.
Posts: 21,197 |
$67 to bleed brakes! Anywho it's something that should be done every two years at the minimum.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 10,015 |
Do IT, DO IT!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 107 |
Thanks What happpens if you don't?
Posts: 1,085 |
Originally posted by harrup: Thanks What happpens if you don't?
Brake Fluid is Hydroscopic......it has the ability to absorb WATER. Result - spongy brake feel , RUSTING parts , poor brake performance.
2012 Lotus Evora
95 Mystique MTX - GONE 395,000 Kms
--------- Both Zetecs
'97 Contour Mtx - stock - GONE
Posts: 4,693 |
Brake fluid has an affinity for water and takes on atmospheric water. You may think that the brake hydraulic system is sealed, however there is no such thing as perfect seals. Minute as it may be, some atmosphere enters the system and water comes in with it.
As brake fluid takes on water, it degrades. At lower levels, the brake fluid absorbes the water and holds it in suspension. The only damage here is that the brake fluid boiling point is lowered. Some brake fluid containers have "wet" and "dry" boiling points on it. The "dry" readings is fresh brake fluid with no water yet absorbed, and the "wet" readings is when the fluid has absorbed it's full capacity of water that it can still hold in suspension. An example may be something like 550�° F dry and 284�° F wet, so you can see that the difference is considerable.
If the brake fluid boils during hard sustaind braking, you will loose brake pedal since fluid is compressable and air essentually is not.
The next critical thing about old fluid is that as it degrades it will become gunky so that you have debris in the fluid leaving deposits. This gunk also becomes corrosive and starts to damage both rubber and metal internal parts. Also the gunky debris can cause havic with the ABS hydraulic control unit.
Changing the fluid is important then for many reasons.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 1,016 |
Originally posted by Big Jim: ... If the brake fluid boils during hard sustaind braking, you will loose brake pedal since fluid is compressable and air essentually is not. ...
Isn't it that air is compressable, and fluid is not? (i.e. air can be compressed) Just thought i'd clarify.
2000 CSVT Silver Frost: #942 of 2150
HID Projectors and Fog Light Mod, Optomized TB, MSDS headers
2003 Silverstone Z
Posts: 107 |
Posts: 4,693 |
Originally posted by epattonm: Originally posted by Big Jim: ... If the brake fluid boils during hard sustaind braking, you will loose brake pedal since fluid is compressable and air essentually is not. ...
OK, I guess I need to review my rusty High School Physics. When you try to brake with vapor instead of fluid the calipers don't get the pressure needed to make them squeeze the rotors. I guess that you would be correct because a hydraulic system must function without compressing the medium. If there is an engineer in the group that better knows the correct verbage, please speak up.
Jim Johnson
98 SVT
03 Escape Limited
