Posts: 4,155 |
Man that UIM is bloody sweet
Posts: 21,197 |
Thought Noble's would have the tumble port heads. So is there an IMRC or something that control's the secondaries or are they just gutted?
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 10,015 |
Originally posted by Todd aRRRRRRRRR.: Thought Noble's would have the tumble port heads. So is there an IMRC or something that control's the secondaries or are they just gutted?
Todd, look again. It looks like a special LIM - it looks taller than the Contour unit to me, and with NO through shaft holes for the secondaries. I wander if it is and adapter to a tumble port head?
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 7,025 |
Originally posted by Stazi: Todd, look again. It looks like a special LIM - it looks taller than the Contour unit to me, and with NO through shaft holes for the secondaries. I wander if it is and adapter to a tumble port head?
i see holes.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 10,015 |
You are right.  He must've had the ends welded and ground flat cos you can't see them from the outside, but when you looks inside the ports you see them.
AUSSIE ENDLINKS $70
Posts: 21,197 |
I took into to Photoshop and lightened and zoomed in. Looks like it is an adapter. So 2ndary butterflys or shafts anyways. That would be nice to do to our cars! Still need to fab up EGR since the UIM would be higher. You would need a cowl hood for the space.
Edit: Guess I still can't tell if it has secondaries. Guess we'll have to wait for Apex.
-'96 SE MTX 3L
Posts: 9,065 |
Originally posted by Todd aRRRRRRRRR.: I took into to Photoshop and lightened and zoomed in. Looks like it is an adapter. So 2ndary butterflys or shafts anyways. That would be nice to do to our cars! Still need to fab up EGR since the UIM would be higher. You would need a cowl hood for the space.
Are you guys blind! THere are no secondaries!
Posts: 316 |
No secondaries.
Remember, entirely different control system on this vehicle. No MAF, no EGR either.
Posts: 316 |
RC Engineering 750CC (71.4#) injectors got here.  Compared with the little 42# Ford Lightning Greentops:
Posts: 9,872 |
that thing is phat! and fat!
