Got the pair of 8" Zirgo fans in. They're the highest performing narrow 8" fans I could find, each rated at 1000 cfm's.
http://www.zirgo.com/detail.lasso?itemid=ZF8Installing the fans, we had to shave a good section off of the bezel to give us the amount of clearance we wanted. We pretty much shaved it within a few mm of the blades. If we wanted more clearance, we would have needed to shave the bottoms, to drop the fans down more, but that was unnecessary.
The wiring is not complete yet, of course, nor is the intercooler box screwed back on the chassis yet.
Here is the view from the front:
Here is the temp sensor plug. We haven't decided for sure whether to silicon glue it into the end tank of the intercooler (right below the exit pipe), or mount it on the fins on the outside. Inside will give a more accurate reading, though it does present some risks as well.
