Page 11 of 19 1 2 9 10 11 12 13 18 19
Originally posted by gotapex:
It uses 265/35YR18 tires in the rear. The stock tires are DOT-R semi-slicks.
I'm afraid I may have just soiled myself. Goodness, are you Noble people ever serious about this car business.
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
gotapex Offline OP
Originally posted by Russell-3L:
how much does the tranny cost?
Sorry, no idea. It's part of the package. I'm sure it's not too bad, as it's from one of the Ford Mondeo models.
Treadwear sucks though. I'm guessing it'll last maybe 5000 miles. However, it should be a fun 5000 miles.
Yeah, that really does say 60 treadwear.
gotapex, truely jaw dropping.
just curious how long this drivetrain project took?
yes... I am a cougar owner trolling on your board.
gotapex Offline OP
It actually took quite awhile because:
1. We were waiting on some parts that were backordered. This was the 6th M400 in the USA.
2. I had my mechanic put in a bunch of upgrades while the engine/tranny were going in. I figured this would be the best way to do things, eventhough it delayed the install a bit.
All in all, it took about 3 months, but most of that was waiting. Actual work time was about 2 weeks.
Q
Q
Off topic, but I had to say this one. We sold a Carrera GT to a guy in Cali like 3 weeks ago. On his first try to drive it, he destroyed the clutch!
There goes $40K!
gotapex Offline OP
New custom intercooler from Bell came:
Core Size: 18" long, 10.5" tall, 3.5" thick.
Core Type: Bar & Plate
Fins: curved, louvered
Old one was a 1.97" thick Tube & Fin, with extruded internal fins.
Stock on top:
I went with a dual-tank on the passenger side, to minimize end tank volume & turbulence. End tank, passenger side comparison:
Comparison of passenger side end tank, top view. Stock on left, only tapers in 1 direction. Bell end tank also tapers width wise. Also, because of the bar & plate design, the end tanks can be fit to the width of the intercooler almost exactly:
Comparison of the fins (Bell is sitting atop the stock intercooler). Bell has greater fin density, and louvered fins.
A closer look at the louvered fins on the Bell, along with close up of welds:
Internal fins, huge difference from extruded stock. Also, notice the air passages go from one edge clear to the other:
Another picture where you can also see the air pipes run the entire width, thanks to the bar & plate design. As you can see, tube & fin type intercoolers, like the stock one, have narrower pipes, and less volume, even with the same intercooler width:
Detail on welds at the end pipe, plus detail on the beaded end to hold rubber pipe:
Wow, that is a hell of a quality piece.
2003 Mazda6s 3.0L MTX Webpage 2004 Mazda3s 2.3L ATX
gotapex Offline OP
Picture of the ugly end of the vehicle (rear end) in front of a fine dining establishment:
H
H
HOT DAMN!
Im glad I tipped Mr. Noble off to the 3L
Tea 82 242Ti Proud former owner - Samantha '98 SVT #2253 Reborn Aug 21 2002 Cobra Paradise
gotapex Offline OP
Finally washed. Took forever.
