Posts: 1,224 |
I'm pretty sure that the tri-y does a better job at scavenging exhaust gasses. The exhaust pulses blend together a little better than with a 4-1. Just my observation.
BTW, that ZXtuner header worries me. It doesn't have a flex section anywhere. If your muffler hits something, isn't there a HUGE chance that you will crack the weld on the head flange?
BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
Posts: 21,653 |
That's because it ends right after the collector, you'd have to add your own.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 7,117 |
Just in case you are not aware, a tri-Y is also known as a 4-2-1 header.
Posts: 7,117 |
Originally posted by ButtonPuncher: ... that ZXtuner header worries me. It doesn't have a flex section anywhere. If your muffler hits something, isn't there a HUGE chance that you will crack the weld on the head flange?
Doesn't the Zetec have a flex pipe under the car, approximately where the V-6 has the cat??
Frankly, the only problem I see with the zxtuner 4-2-1 header is that you'll need to buy a high-flo cat to stay emission legal, but that's no big expense. And if you're clever, you can put off adding the cat for a little while... by keeping the car off road only I mean...
Posts: 21,653 |
It does have a flex pipe, but are you gonna run the stock small exhaust/flex pipe after buying a header? And what is "emissions legal"?
98.5 SVT
Posts: 7,117 |
Originally posted by Kremithefrog: It does have a flex pipe, but are you gonna run the stock small exhaust/flex pipe after buying a header?
Until there's money for an exhaust upgrade, there's no real harm. Just a small performance hit which will be about the same as running an SVT exhaust with a cat - maybe even less.
Originally posted by Kremithefrog: And what is "emissions legal"?
Posts: 52 |
I would like to upgrade the whole thing at once. Im currently scouting around for a shop that would do the welds but I'm a little unsure about the details of what I would need. I'd like to pass emmissions... but I'll explore other options if need be...
Posts: 8,143 |
I've seen some Duratec guys purchasing flex pipe...I'm sure u could get one and just weld it in.
Posts: 52 |
Thanks guys for ALL your help! Especially Tourdeforce with his VERY insightful comments. I think I've made my decision, and now I'll be making the buy in the next month. So Watch OUT for my pimped out ride!
