Page 2 of 7 1 2 3 4 5 6 7
Master P
Master P
Squeeky driver's seat, fixed twice, still does it
Dome light was blowing fuses so it's now sitting on my desk
Remote release gas gap wouldn't open, fixed by TSB
CV Axle was slinging grease
Front sway bar bushings are toast, new ES bushings sitting in my room for the past 7 months
Couple of outstanding recalls that I won't get fixed
Driver's side front window won't roll down -- regulator is toast
Plunger on the door was malfunctioning and drained my battery, fixed by cleaning the contact
96 GL Zetec ATX 82,000 miles
LOL! laugh I know how you feel. I've had my ES motor mounts and ES bushings sitting in my garage for like six months now. A combination of too lazy and not enough time to install them. Hey, maybe I'll do it this weekend LOL!
As far as problemas, 53k+ miles (90+ each day) and no problems yet except for noisy suspension, which I know I need to replace all of the bushings, and I'm going to go with the Ground Control kit with Konis when the time comes, which is really why I'm waiting on the ES bushings...
Regards,
Craig J. Baldwin
99 SVT Contour - Silver - #49/2760
"To make a living is to get, to make a life is to give." - Winston Churchill
1999 SE Zetec ATX.
49k miles
Thermostat and coolant replaced. (Solved overheating problem)
Replaced driver mirror. (Motherf---ing orange barrel!:mad smile
That's it for major repairs.
P. Valdez
1998 VW Jetta TDI
1.9L I4 direct injection turbo diesel
5 speed manual
no mods, no money
AIM:PackRatTDI
My exhaust smells better than yours.
1997 GL with Duratec - drove to 69,000 miles.
Wheel alignment at around 13,000 miles and battery at 63,000. The rest was all basic maintenance. I usually changed the oil at 4000 mile intervals.
59,9xx
A/c recharged at 58k
struts replaced at 55k (Eibachs on stock struts)
3rd gear synchro (yet to be fixed)
leaking trunk (don't know how to fix)
60k mile check (I passed, YAY!)
Other stuff was just maintenance
Josh
Aka Spectra SVT
02 Dark Highland Green F-150 XLT
Mods: Gunrack and cowboy boots
Had 53000 miles
Problems: Hit ice.
O
O
98.5 SVT - 42000 miles
30,000 miles - Clutch replaced
30,000 miles - Brake pads replaced (warranty)
35,000 miles - Main cat replaced (warranty)
40,000 miles - Steering rack bolt replaced
99 Zetec 51K
No problems whatsoever...i love my car laugh
99 SVT...modified
96 GL....the beater
"I live my life a quarter mile at a time. For those 14 to 15 seconds, 16 if I get tire spin, or get a bad jump, or possibly if I have a friend in the car, I'm free."
4
4
98.5 zetec, 52,600 miles right now, had 25,000 when purchased used 2 years ago.
exhaust system connection between flex pipe and resonator pipe broke-26,000(not long after buying car)
trans leak-35,000(just before warranty expired)
blower motor resistor, switch, and wiring-46,000(program covered it)
back end of car sitting too low, replaced rear springs, not broken, but getting there-48,000
right front wheel bearing-49,000
replaced tie rod ends, were starting to sieze up. also performed alignment.-50,000
Since I work at a Ford dealer, I have saved myself lots of money by doing the work myself. I get a parts discount too.
Justin
'02 Ranger Edge ext cab
Retired: 98.5 Mystique
'99 SE Sport V6, 48k
ESP Coverage:
1. Passanger Control arm (my fault but i have a hook up in the ESP company)$25
2. Light switch assy. (Also my fault after botched Fog Light fix try)$25
3. Cam sensor (Evedently my car thought it didnt have cams, ran like sh!te)$25
Non ESP Coverage:
1. 4 new wheel studs and bolts (hit a curb and broke 2 had all 4 replaced)$100
So i guess in essence i guess i have had only one problem and it was the Cam Sensor. LOVE MY NAVI!!!
'99 Contour SE Sport, 50k, V-6, ATX, T-Red, With Many many mods.
'99 GMC Sonoma SLS, 16k, 4-cyl, Summit white, not as many mods.
Founder of Ghost Tech Racing inc.
AIM-FordMondeoS
"Time does not exist in this dimention; but in a time and a place we know not of..." -A. P. Stidwell
