Yes...
The oil pools in the recesses of the heads. (i.e. the head walls are tall) The cam covers do top the heads but if you look at them they are not very tall.
If you wanted to try and help the problem you could drill the rear side of each of the heads right at the base of the corner and put a LARGE hose that ran down into the pan.
The logic behind this is that the oil must pool in more volume in the rearside because it's a right hand susceptibility.
Of course the work and money involved to try a project like this would make an accusump look like a much wiser investment. It's also tried and true.
