Posts: 65 |
Earlier this week, my car stopped moving forwards or backwards. My sister was using the car.... It was in gear and she was lighly accelerating when this happened.
The tranny had been not acting up, no weird noises, and had JUST completed a 200 mile highway trip. The tranny had fluid, it was fresh probably 5000 miles ago.
All gears including reverse can still be selected. When I let the clutch out, the speedo goes up. Under the car, there is NO movement from the transmission, as in neither of the axle shafts are turning from the tranny. My best guess is that something in the differential let loose, but does anyone else have any suggestions?
Matt
Posts: 1,145 |
i dont know the specific's of the MTX-75, but it sounds like you blew out the differential. but like i said i dont know exactly what part of the tranny the speedo gets its info. But if it will go in gear and the speedo goes up and the car does not move, it is most likely the Differential. If you do decide to replace it, get a performance one so that this stuff dont happen again
98.5 Black SE ATX
Posts: 212 |
Matt see my post in the New Engalnd forum. Rob
Rob Collins
98.5 svt blk/blue #5778of6535
I've got some mods.
Posts: 5,810 |
Sounds like a broken clutch. Diff doesn't go out without a bang and a cracked trans case with fluid everywhere.
Chances are the disk is broken at the hub or the friction material is gone and it is spun out.
Figure $600-$1000 unless you do it yourself.
See My Mods
Posts: 2,097 |
That is how my diff broke...cracked the case!!
98 E0 SVT with some stuff
Posts: 3,732 |
if the speedo goes up, it sounds like a borken axle to me!
thats the first thing id check
Russell
Oval Port 3L Nearly Done
Posts: 9,602 |
Woo hoo...
I disagree.
The speedometer (VSS) would not go up if the clutch was not linking the engine to the transmission.
I would most likely surmise a broken axle shaft.
Worst case scenario even broken spider gears but that's more unlikely.
You can break the spider gears without catastrophic transmission failure.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 5,810 |
Originally posted by Russell-3L: if the speedo goes up, it sounds like a borken axle to me!
Speedo?
For some reason I thought he meant tachometer. Then I stand corrected. IT probably is a broken axle shaft since that will allow the differential to spin. Still, it probably isn't a broken differential, especially if he is getting a speedo signal.
See My Mods
Posts: 5,810 |
Originally posted by DemonSVT: Originally posted by warmonger: Sounds like a broken clutch. Diff doesn't go out without a bang and a cracked trans case with fluid everywhere.
Woo hoo...
I disagree.
Worst case scenario even broken spider gears but that's more unlikely. You can break the spider gears without catastrophic transmission failure.
Yeah Yeah.
Disagree that it is a clutch I hope, not about the diff.
See My Mods
Posts: 1,145 |
see i told you i didn't know what i was talking about, i told you i was an idiot when it comes to the MTX-75
98.5 Black SE ATX
