Posts: 9,872 |
Originally posted by dion:
WOW
shave yourself a cut off line an man that pattern will be smooth as a baby's arse! It still looks good
Posts: 1,036 |
Originally posted by Goonz SVT: Originally posted by dion:
WOW
I do have a cutoff, this is the normal pattern of the H9's, and the H7's as well I believe. The H7's will be sharper, and Milan's don't count because he modded his own shields to get that beautiful cutoff.
As for the other pic, if you'll notice, the left beam is a nice "blue/white", while the right beam is the halogen white. The pattern on the ground is perfect, nicely dispersed.
Milan, I'm currently waiting on an email back from the distributor, but of course, the aftersale support sucks. He may just get a negative feedback from me, or if I'm nice, a neutral feedback....
dion
98 SVT, 200 whp/190 lb. ft tq (tuned by ADC), 3.0, P&P heads w/2.5L valves, optimized TB, MSDS, SCA 2.5" catback, SHOshop UIM/LIM, underdrive pulley set, TD's, Koni/H&R, BAER/TCE, Progress, CF1 products
Posts: 9,872 |
your right, you do have one, I see the " Z " pattern
Posts: 2,529 |
Dion, good luck with this one man. I hope it works out for you. Kevin (I-Dom-In-8) had to wait like a month to get his when they made a "mistake" by sending him a 4100 kit instead of the 6000 he wanted...
You are correct, that is the normal H9 beam pattern. The H7 has a different one in that the right side does not tapper off but goes up on an angle, something like this ___/
