Originally posted by bnoon:
How? The T-stat is a physical piece that operates just as any other T-stat does, the water pumps are physically driven...
I am talking hot weather here (hence the previous reference - in cold weather the t-stat does control temp level)
The computer is pre-programmed to keep the engine at a specific temperature via the cooling fans.
If the temperature goes below this preset parameter the engine would fall back to open loop mode (engine warm up) until it reached the proper operating temperature. (I.E. very rich)
This situation is not likely during warm weather. However cooling system modifications & engine/engine bay cooling help could be made to accomplish this.
My car runs ~185 degrees and rarely even breaks 200 degrees in spirited or stop & go driving.
Now would I like the car to run cooler. Heck yeah! However without changing the PCM's preset specs it will not work out correctly.
About t-stats. According my 00 Ford CD's it is 180 degrees. However someone else posted they had a 190 in from the factory (96 or 97 model year IIRC) So???
I recommend 180 degrees either way.
BTW - I do not have, nor run an Electric water pump. Yes I do plan to do so in the future (23k now - half way to w/p death :rolleyes: :p )
I think an electric w/p will give ~50k miles of use before requiring a rebuild.
I think it's benefits are tremendous. Imagine the drag it exerts on a "single camshaft" at 6-7k rpm... I can definitely see how those power gain claims could be true.
Complete controllability of engine cooling, heat soak, etc. I know at the Auto-X meets that would be great since you run 4-5 times repeatedly in ~10 minutes increments. Staging lanes at the strip...
