Posts: 21,197 |
Originally posted by contoured: Go For the MIL-ELIMINATORS
You do know what that does right? I guess not if you mentioned it. MIL elim. are not a fix for this code. I'm guessing a bad EGR or DPFE. Tube under the TB might be carboned as well.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 635 |
Originally posted by 99_2.5_V6: TSB 04-15-16
ISSUE
Some 1997-1998 Contour/Mystique and 1999 Cougar vehicles equipped with the 2.5L engine may exhibit a malfunction indicator lamp (MIL) illuminated with diagnostic trouble codes (DTC) P0420 (Catalyst System Efficiency Below Threshold - Bank 1) and/or P0430 (Catalyst System Efficiency Below Threshold - Bank 2).
ACTION
Replacement of catalysts is no longer necessary to address the most common causes of this condition.
-------------------------------------------------------------------------------- ACTION Replacement of catalysts is no longer necessary to address the most common causes of this condition.
This is a laugh-- it's no long a problem because it it doesn't help Ford's bottom line? Correct? Unless I've completely mis-undetstood the "pre-cats" problems, I've been under the assumation that the cores/substrate are burning up (not sure of the correct term)? The clogging was because or melting or disintegration of the substrate? Is this a design problem too small area for the amount heat this engine produces or is it all these minor-mifires I see ever 15k-20k miles. (new plugs eliminates). Of course this would mean the bank one pre-cat would be the first one to go. Two contour owners that have had them replaced the where told only one was bad but both where replaced?
Any ideas or thoughts!
TNX Paul
Paul
98 Mystique LS 2ea (07/97)(08/98)
Posts: 635 |
http://www.motorcraftservice.com/vdirs/PCMflash/Latest_calibration.xls
Excel file
IE: my 98 Mystique LS tear tag code "KCA3" and they show a Update TSB 98-13-11 part no.F7PF-DPA
It appears even Zetecs are involved with 98-13-11.
Anyone have access to this TSB. I don't remember if I have a source on-line or not?
Paul
NEVER MIND
98-13-11 JUL 98 A/T - CD4E Harsh Shift On 1-2 Upshift/3-2 Downshift
I should have remember this It's a reprogram for the ATX.
Also TSB 04-10-4 exists also for DTC p0420 & p0430??? Title no acess to text.
Paul
Posts: 1,788 |
Originally posted by todras: Originally posted by contoured: Go For the MIL-ELIMINATORS
Todras,
Actually, MIL Eliminators will help with the P0420/P0430. After all that's what they're for!
The P0420 and P0430 codes are generated when the downstream sensors switch too fast, that is, too close to the switching rate of the upstream sensors.
The purpose of the RC integrator circuit that is the MIL Eliminator is to slow this switch rate down so that the computer sees a longer term average reading with considerable lag - just like a normal downstream sensor would produce if the converter was working at reasonable efficiency.
Steve
89 Taurus SHO - 246K miles
94 SHO ATX - 190K
Posts: 1,322 |
I think you are refering to the fix for P0402, the post says P0420.
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760.
"Many posted questions are answered by farm boys"
Posts: 140 |
08/09/04 MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DIAGNOSTIC TROUBLE CODE(S) P0420 AND/OR P0430
FORD: 1997-1998 Contour
MERCURY: 1997-1998 Mystique 1999 Cougar
ISSUE
ACTION
Reprogram the powertrain control module (PCM) to the latest calibration using WDS release B32.5 or higher. Calibration files may also be obtained at www.motorcraft.com. Replacement of catalysts is no longer necessary to address the most common causes of this condition.
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
Does anyone have this TSB?
Posts: 1,788 |
Uh, THAT is the TSB!
Steve
94 SHO ATX - 190K
Posts: 140 |
Uhh, the actual one from a link or some other document. I printed the one pasted here and they looked at me like I'm nuts!
Posts: 1,788 |
Go to a dealer that has a clue (and an up-to-date database).
steve
94 SHO ATX - 190K
