Posts: 168 |
I got out the OBDII scanner this weekend to track down an intermittant MIL (turns out to be bank 1 lean condition - damn. why couldn't it have been bank 2?).
Anyway, I am an engineer, and I like to see all that quantifiable data in the engine controller. So OBDII scanners make me feel like a kid in a candy shop, or R Kelly at junior high.
But I don't understand what long term versus short term fuel trim is. Percent of what? % injector duty cycle? What are expected values? I noticed that bank 1 (the problematic bank) values for LT fuel are quite different from bank 2. What can I learn from this, apart from what the MIL already told me?
-Kurt
"I'm a little sceptical of that internet thing. After all, what's it got besides information?" -DB, 1/97
Posts: 3,419 |
My understanding of the Fuel Trims is as follows:
The ST and LT trims are additive to the injector duty cycle. So, if you have LT of +8 and ST of +2, you are going to get 10% more injector open time. (This I'm NOT sure of, but I think it's how it works).
The LT trim is changed when ST trim stays at an elevated (away from zero absolute value) value for a specified amount of time (not sure how long) at the same engine conditions (MAF, Load, TPS, etc.). The goal of the LT trim is to keep the ST trim near 0 absolute (I think +/- 3 or so).
As far as one bank being much different from the other, my guess is that it could be clogged fuel injectors or intakes, or a dying O2 sensor. But, these are only guesses and I don't have my Service CD handy. I'll try to give you a more complete answer later. Can you give me the exact code you read?
The lean codes fire when LT + ST trims > +30% (i.e. the PCM is at it's wits end trying to add fuel to stay stoich in closed loop). Check the "Freeze Frame" for what was going on exactly when it fired.
Posts: 422 |
Does anyone know if the PCM applies the LT adjustment at WOT or only in closed loop? I know ST is closed-loop only....
2000 Mercury Cougar V6 ATX. 16.0@87MPH, 155.0 FWHP
Posts: 7,329 |
My ST trim alone is 28-38% (depending on rpm)
Posts: 52 |
that's the most confusing thing I have ever read
99 Green Contour SVT (still gotta find out the number) 17'' Millie Miglia Cello, 225/45/zr17 Toyo Proxes FZ4's, True Rev, Borla, Amber removed, BAT Struts Soon: PIAA 510 fog lamps
Posts: 316 |
My SHM MAFterburner has allowed my Contour with larger than stock injectors to run a -1.5 to .5 LT fuel trim. At WOT it jumps up to 38% ST fuel trim lean. But the 02 takes over at WOT. So the ST is off no value. The 02 values now read either .93 or .94 and .92 at the secondary actuation.
An useful tool.
98 T-Red Contour LX V6 Mtx 106k miles 9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
Posts: 316 |
I found this informative.
Before starting to tune WOT, it is a good idea to hook up an OBD-II scanner (like Autotap) and monitor the STFTs and LTFTs for both bank1 and bank2.
The LTFTs give you a very good idea of how your system has "adapted" to your intake/fuel system mods. They are just time averaged STFTs. The maximum deviation of the LTFTs is +/- 25% and demand for anything beyond will throw a code (if STFTs are also > 5% in the same direction). When the car is new, the LTFTs will most likely be less than 5-7% across the entire data array. When tuning the closed-loop system with the MAFterburner our goal is to hit 0% LTFT but anything less than 5-7% in either direction is acceptable.
Let me step back, the LFTFs and STFTs are not single variables but data arrays which vary with load/RPM. Therefore, when you are tuning, you try to run the car at many different load points while monitoring the trims and making adjustments with the MAFterburner's closed-loop table.
The first thing to do is hook up the scanner and drive around monitoring the LTFTs and STFTs. If they are smaller in magnitude than 5-7%, you have nothing to really do. However, if you wanted to get them closer to 0%, you could fine-tune your system using the MAFterburner.
Here is something that I posted on the Corral:
If you have an Autotap (or any other OBD-II scanner) then you can completely recalibrate your MAF to accurately represent your new system yourself. Here is how:
If you have made changes to your intake setup, you may be misleading the PCM into thinking that your car is running richer or leaner than it actually is. The reason is that these changes may have caused the MAF measurement system to go out of calibration and the result is your PCM "adapting" to this faulty information while operating in a closed-loop operating strategy. Provided that there is enough dynamic range left in the STFT/LTFTs, you will not experience a fault condition BUT it may negatively affect your WOT tuning.
This is the reason for CLOSED-LOOP tuning with the MAFterburner System.......to bring everything back into CALIBRATION using the PCM's "adaptive" system as a tuning guide.
More Information:
The STFT/LTFTs indicate just how the PCM is modifying the injector pulse widths to maintain stoichiometric (14.7:1) A/F ratio while running in closed-loop operating strategy. No matter what changes you make to the MAFterburner, the PCM is going to adjust so that it maintains stoich (as long as it doesn't run out of fuel trim). If it runs out of fuel trim (i.e. meets certain criteria), it'll throw a code. The only real reason for tuning this closed-loop system using the MAFterburner's CLOSED-LOOP table is to fix any large deviations in the intake setup caused by aftermarket mods. Why bother with this? Because the "open-loop fuel modifier" is taken from the LTFTs. So, at a given load/RPM condition, if you made an intake change that caused the fuel trims in that cell to richen by let's say 10% (+10%), and you go WOT from that cell, 10% fuel will be added to the calculated injector pulse width and the car will run richer than ideal (on some model years). So, by tuning this closed-loop system to achieve near-zero LTFTs in all cells with the MAFterburner's CLOSED-LOOP table, you are effectively insuring that the OLFM will be zero. The next step is to make the EXACT same changes to the OPEN-LOOP table so that you have a good baseline to work from. That way, you can use the MAFterburner's OPEN-LOOP table to tune WOT on a dyno and you can be sure that the PCM will not have to make any large corrections over-time to what you tuned on the rollers. This may be confusing but let my try to give two examples:
1. Let's say you're on a dyno and go WOT from cell X. In cell X, the LTFT is +10%. So, let's say that the PCM tries to maintain OL a/f ratio of 12.0 and measures the MAF signal and computes the pulse-width to achieve that a/f ratio. However, the PCM adds 10% fuel to this because it "learned" that the car generally runs 10% leaner then demanded when in closed-loop operation. If you haven't messed up the "calibration" of your intake system (i.e. the transfer function in the PCM matches that of your actual system) then you get 12.0:1. However, if you've changed your MAF or added a CAI or made some other changes to throw off the transfer function (MAF is out of calibration), then you don't get 12.0:1, you get 10.8:1 which is too rich.
2. Take the same example as above. Now you use the MAFterburner's CLOSED-LOOP table to effectively zero out the LTFTs across the entire load/RPM range. Now when you go WOT from cell X, you get the PCM's desired a/f ratio of 12.0:1 because the OL fuel modifier is near zero. Natural changes still effect the trims and the system functions as normal (i.e. O2 sensors age, etc.) BUT you have essentially RECALIBRATED your intake tract to precisely match what you REALLY have. No other MAF tuner-like device can achieve this goal!
In conclusion, the novelty behind the MAFterburner is that it allows the tuner to "correct" for inadvertant changes made to the intake tract (including CAI, new MAFs, cams, etc.) via user modifications. IMO, this tuning method is unique to the MAFterburner system. The tuner uses the PCM's LTFT/STFTs to "see" precisely how the system calibration has been thrown off and uses this information to essentially recalibrate the system.
Posts: 102 |
98 SVT
Posts: 2,794 |
Mr. Munson....overthinking as usuall
Just call me Judge. People suck. Life begins at 170mph...until that point it is just boring.....
Posts: 852 |
Very informative. A challenge for my monday morning brain, but very informative...
Marco Tatta 98.5 SE MTX, Duratec EGR block, fog light fix, custom shift boot, monsterflow intake, Ecotek valve Quasi dual cardoctor exhaust. Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
