#120497 06/22/02 09:06 PM
I just put on my Pro-FLow MAF a month ago, and in the last two weeks I got a too lean on bank 2
code. Has any one else experienced this or do you think something else might be causing my code
#120498 06/30/02 03:12 AM
I just had that code about a week ago and took a day to track it down, turned out to be a leaky valve cover gasket... replaced and now there no code. Check for any leaks in you vacum system if you find one. then thats prolly whats throwing the code
99 SVT with resonatorless exhaust and open element intake
Sound System:
Clarion touch Screen Source Unit
Focal Components,Audiocontrol eq,
eclipse Subs and Amps
#120499 06/30/02 03:46 PM
No vacuum leaks that I could find
#120500 07/01/02 06:03 PM
I have the same code. when i go to the dyno i am gonna boost fuel on my safc and see whats up then
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill|
Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
#120501 07/01/02 11:48 PM
Yeah for me it's wierd, I got it once, my buddy took it to work, checked the fuel stuff and for vacuum leaks but he found nothing. So he deleted the code. Then two weeks later the code came back again, so I replaced the plugs and wires. All good the it just came back again.
#120502 07/03/02 12:20 PM
Justin, maybe you have a faulty O2 sensor. If that were the problem, it would be completely coincidental with the new MAF being installe. But historically, O2 sensors are prime candidates for lean OBD2 codes, at least when the stock MAF is retained.
-Kurt
"I'm a little sceptical of that internet thing. After all, what's it got besides information?"
-DB, 1/97
#120503 07/04/02 12:59 AM
Ok, I put on the stock MAF any it came on again, so I'm finally sure it isn't the 75mm MAF. This is really starting to vex me, cause my car isn't running well and its so nice out and I can't go racing around. Anyone know how to check a O2 sensor. I don't remember much from auto class except you need a torch?
#120504 07/04/02 01:39 AM
What you need to do is get a filter screen from BAT. It diffuses the air coming into the throttle body. It is only like 10 bucks, too. I hear that this will solve the issue.
Po-Jay
Ghetto Mods Galore!
Quaife-CenterForce Clutch-Butterflies Rmvd and Replaced again-Bassani Exhaust w/custom "Y"-Pipe-33% of Mystery Mod-Pro M 75MM MAF-BNoon Optimized SVT TB-B+M Short Throw-ES Front Engine Mount-Some Aesthetic Crap-
Blood,Sweat,Tears
Do I hear the Fat Lady singing?
98 E0 Silver Frost (Is there any other color?)
172HP 149TQ W/Bad A/F Mix
#120505 07/04/02 05:33 AM
How would that solve a lean problem?????
#120506 07/06/02 07:56 PM
W
W
Are there any known side effects to putting a 75mm MAF on the SVT Contour? I am thinking about buying one but I want to know if I am gonna harm anything.
Thanks
1998.5 Silver Frost Contour SVT #5957 of 6535
List O Mods
PhAtRiDe
