Hi all! I have 1999 Contour LX. I just wanted to know is it normal to hear a ticking sound after you turn off your the car. If this is not normal is there anything I could do about it?
engine, exhaust cooling down, normal.
-Louis
1998 Black E0 #3826, lightly modded
Usually from the cat (convertor, you sickos). Yes, it's normal. Should start out as a fast ticking, and get slower/quieter as it cools.
95 Contour SE ATX V6
"Cracked" Secondaries
DMD Installed
SVT Brakes
From what cats,I have a off road y pipe and mine still does it
Black '98 Contour SVT
#162 of 6535
-Indiglo Gauge cluster-
-Kenwood KDC-X815-
-Audiobahn ALUM12x sub-
-Audibahn 18001d Digital Amp-
-Audiobahn 1.0 farad cap-
-LED side markers/washer nozzels-
-KKM Intake - Bosch Plat. +4-
-Custom Exhaust - NO res.-
-Sho Shop off road Y-pipe-
-Fog light fix - THX-Fix-
-Koni strurts - Roush springs-
The precats then? There are 3 cats on every Contour. If you have changed headers also, then it could just be from heat shielding on the exhaust components, or the pipes themselves.
DMD Installed
SVT Brakes
