#120421 06/20/02 05:42 AM
Bridge Offline OP
I am about to do this mod within the next 2 weeks, but I was wondering, will the new K&N fit in the stock air box?
98.5 Contour SVT - Silver Frost
Cupholders - MP3 Deck - Sub - Painted Calipers (Silver) - K&N Filter
#120422 06/20/02 06:23 AM
If you are buying the K&N drop-in it will fit just fine. It's good for 1-2HP.
However the MAF may be a bit more tricky, but the acordian tube should allow for it's extra length if fully compressed???
2000 SVT #674 - Check it out!
#120423 06/20/02 02:41 PM
I couldn't get my MAF and stock airbox to fit in the car. The airbox has some funky angle to it...there was no way the airbox was going to plug into that fender hole.
Uh...just reread...I don't think a larger K&N will fit into the stock airbox either.
Hope I answered your question. :rolleyes:
2000 Silver SVT #1602
Check it out in the registry!
Mi Coche
#120424 06/20/02 04:01 PM
Bridge Offline OP
So if the K&N and the new MAF won't work with the stock airbox, won't that decrease HP?
#120425 06/20/02 08:02 PM
Bridge Offline OP
I phoned K&N and the new filter will fit in the stock air box, but apperantly the new MAF won't... is that right?
#120426 06/21/02 10:39 PM
K&N does have a filter that will fit in the stock airbox. However, I was not able to get the 75mm ProM MAF to fit w/ the stock airbox.
My solution - ProM MAF and a 6" long open air filter. Works well. I'm building a heat shield as we speak.
I don't understand your "decrease HP" comment. Care to clarify?
Mi Coche
#120427 06/21/02 10:42 PM
Bridge Offline OP
What I meant was that if the MAF did not fit the stock air box wouldn't that cause a decrease in HP... Not overall, but a decrease in HP due to having no heat shield
#120428 06/22/02 05:20 AM
It means the filter would be subject to heat soak in hot weather and stop & go driving. Heatsoak will degrade performance.
This is why folks with open air filters make heatshields and have cold air supply hoses feeding the filter area. Thus getting the benefits on an open air conical filter, avoiding heatsoak, and supply colder air to the filter area.
If you have ever looked at the stock SVT airbox you realize it has to pull all of it's air through that tiny inlet hole at the end!
#120429 06/22/02 04:36 PM
Bridge Offline OP
Does BAT make the cold air supply hoses? Also does anyone make a heatsheild?
