kinger Offline OP
Do exhaust leaks have that much effect on the sound of a exhaust system? I just replaced my intermediate pipe between the MSDS "Y" and the beginning of the catback exhaust with a 2.5" hi-flow cat and pipe, but I had trouble lining up the 2 bolts for the catback and the end of the new cat converter and I'm not real sure if it is a good seal. Anyone have a leak right there then get it fixed and have the exaust sound drastically different? If it doesn't then I'm pissed cause it sounds like shizzle and tomm morning I had a appointment to get my rear ultraflows replaced with bullets cause it wasn't loud enough, now I'm torn. Anyone know if a cat takes time to break in and sound good, I also had to tilt the cat at a 45 degree angle to fit because Stanzi took the "S" out of it like there is on the stock one, would that have any impact?
2000 Roush Cougar MTX
MSDS Headers, Rear disc conversion, SVT TB and IM, Custom 2.5" exhaust, Weapon R Dragon w/kkm MAF adaptor, B&M, NR wht gauges
I think they might make your exhaust note sound a bit muffled on acceleration and putty (almost backfireing sound) on deceleration.
Do they have any affect on pwr/tq?
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
Possibly louder (bigger leak) Depends on size of leak
Definitely hear that "putty" / leaky sound
Yes they cause a small loss of power.
2000 SVT #674 - Check it out!
kinger Offline OP
That putty leaky sound must be what I am hearing when I let of the gas and decel up to a stop. I must have a leak there, still unsure if I'll swap the rear mufflers though, I have a appt in 2 hours! Thanks for the replies
I always thought exhaust leaks made it very whiny and high-pitched. confused
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
