#1202587 03/02/05 04:05 AM
Occasionally when I go to start my Contour (99 Contour SE with V6 Duratec) it makes this demonic high pitched noise. IT's very random and say it makes the noise, wait a couple seconds try to start again and is fine. Othertimes it will continue to make the noise for up to 5 minutes.
I really have no clue what is causing it, so if anybody knows anything please let me know.
- M. Blunk
1999 Contour SE/Sport 6 Cyl. Duratec ATX
#1202588 03/02/05 04:10 AM
That's the death squeal of the starter. It's getting hung up on the teeth and is over-spinning as the engine starts.
You can pull it off and clean & lubricate the bendix. (lithium grease or something similar) That's a 50/50 shot.
Otherwise it will need replacing in the near future when it finally gives out.
#1202589 03/02/05 02:04 PM
Is is like a wail/honking howl? IF so it may be "the moose",
If it is, look up "moose fix" or "TH fix" onthe main website "how-to's"
#1202590 03/02/05 04:20 PM
Do SVT's do this? I think mine might be.. How pricey is a starter for an SVT?
#1202591 03/02/05 05:29 PM
Starters are not too expensive. Installing one on an ATX is a *(%^*%^*)&%^&(^(P&%&%_(&%&*%)(*(&%)(^^*(% !!!!!!!!
I feel better now.
#1202592 03/02/05 08:08 PM
~$110 with a lifetime warranty.
#1202593 03/03/05 01:22 PM
that's not too bad... for not knowing anybody for a hookup. the lifetime warranty is very useful too
Semper Fi... It's Hard To Be Modest When You Know You're The Best...
#1202594 03/04/05 03:39 AM
- M. Blunk
For a minute....I thought it might be caused by a flaming response from DemonSVT!
Bob
