Page 2 of 5 1 2 3 4 5
#1202057 03/03/05 11:03 PM
N
N
do i stand a risk of breaking my stock brackets if i use the bat sway bar on the stock brackets and end links?
thanks again
#1202058 03/03/05 11:19 PM
Yes, you would stand a risk of it. Many have broken their brackets with the STOCK bar. Do you drive agressively (Why else would you care about a BAT bar)? If yes, you WILL eventually break your brackets with an aftermarket sway bar.
1999 Blk/Tan CSVT #654 - SOLD 2003 Suzuki SV650s
#1202059 03/03/05 11:30 PM
Originally posted by mcgainer:
And and...they also have some pretty cool light-weight front sway bar links...I think I'm gonna order me some of'dem...
Check with your dealer first. I bought a set of those at the Ford dealer for my SVT. For $23 CDN each.....
I also used them for the REAR links on my late father's Mazda. Bolted right up, and cost a quarter of what Mazda wanted.
98 Silver Frost SVT 97 BMW 540I Sport, six speed "Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future" "A coveted car should never stunt your life, but should make it more rich and interesting."
#1202060 03/04/05 12:59 AM
N
N
well i don't auto-x or anything, but i definitely have a need to stiffen up my suspension. and i thought if i could get this bar for 80 and bolt it right in i'd be doing a good thing. if i stand the same risk breaking the brackets on the stock bar, but do you think the brackets will break much easier with the bat bar and poly bushings? if so, do you know why? (for curiousity purposes) i love this car...but i am learning it has some weird weird tendencies haha...put it to you this way: what would you do? would you upgrade to a bat rear sway bar on stock brackets with poly bushings or just leave the stock bar and replace the bushings to poly (if they are broken)???
thanks again
#1202061 03/04/05 01:42 AM
The reason aftermarket bars have a greater chance of breaking the stock mounts is that they are stiffer. The whole point of using poly bushings or a larger bar is to stiffen up the suspension. With that added stiffness comes added pressure on the mounting brackets, which are barely adequate for the stock bar. If you add a larger bar, you WILL eventually break the mounting brackets.
I broke one of my mounts with only the addition of poly bushings, stock sway bar. Once I had the mounts reinforced, then I added a BAT bar.
#1202062 03/04/05 02:22 AM
N
N
okay cool, i have a MUCH better understanding now...whats the best way to beef up the mounting brackets?
#1202063 03/04/05 06:13 AM
Check out the group buy for the ATI subframes
ATI Subframe
#1202064 03/04/05 03:58 PM
N
N
do i need to do anything like beefing up the subframe brackets if i am planning on lowering the car on ground control coilovers? (struts undecided at this point)
#1202065 03/04/05 06:59 PM
Not necessarily, but its a good idea regardless.
#1202066 03/09/05 05:48 AM
N
N
any opinions on kybgr2's vs. sachs, with GC coilovers?
