Posts: 1,190 |
hasn't anyone installed these on the 3.0 yet?
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese!
diamond pistons for 3.0/forsale
#702 of 2150
Learned patience the hard way
Posts: 2,454 |
Yes I've installed them on a 3L over a year ago. the main thing to reference is if they are made for the 2.5 spec then they will be very slightly shorter which only means that there will be a small error in calculating the compression ratio. However if you have a 3L spec rod length and use it in the 2.5 then you have just decreased the piston to valve clearance which is very minimal anyways. What does Pauter say the center to center measurement of their rod is?
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 110 |
Did Scat mention any possibility of offering a crank along with the rest of the parts for a complete rotating assembly? if so we would be interested.......
Posts: 2,353 |
Originally posted by rac74: Did Scat mention any possibility of offering a crank along with the rest of the parts for a complete rotating assembly? if so we would be interested.......
Why? Our stock forged crank can take more power than anyone will likely ever put on this platform...
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
Posts: 142 |
From the little research that I've done all of the Contour SVT's came with forged cranks, however, only after xx year did Ford start putting the forged cranks in the other Duratecs.....can anyone elaborate?
--Adam
Posts: 3,732 |
will they be available for the 3L, with a 1mm overbore, and in any reasonable compression ratio?
Russell
Oval Port 3L Nearly Done
Posts: 9,602 |
ALL Duratecs (2.5L or 3L) have the same fully counterweighted forged billet crank design.
The balancing is of course different on the 3L engine.
Which for the record has supported over 1200 HP. The crank is not an issue.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 110 |
Since it is a forged crank, I agree that the stock crank is more than enough.
Posts: 344 |
Originally posted by Buckshot77: "the 2.5 rod distance between centers is 138.049 >138.151 MM and the 3.0 is 138.176"
Quote from Terry.
This is absolutely, positively, 100% incorrect information. ALL 2.5L and 3.0L Duratecs use the same rod no matter if they are Escape, Taurus, Contour, Mondeo, or Lincoln LS. This rod has a center-to-center distance of 138.1 �± 0.040mm. And that's straight from the blueprint of the rod, folks.
The ONLY exeception to this rule is the 2.0L (yes, 2.0L) Duratec used by Jaguar. It is a basically a short stroke 2.5L. Unique piston, crank, and rod.
Posts: 142 |
Actually, thanks to Mr Haines, I have the actual Ford factory specs for both the 2.5L Duratec and 3.0L Duratec Connecting Rods....and they are in fact slightly different.
The wrist pin's are slightly larger on the 3.0L Rods and the center-center length is different.
--Adam
