Page 2 of 6 1 2 3 4 5 6
#1201046 03/01/05 04:09 AM
I run 18's with a 225/40 and i still have room to lower, which i'm in the process of collecting parts to do you could have definatly been able to go with a thicker tires.
~Alex
#1201047 03/01/05 04:32 AM
looking closer, looks more like u put a lift kit on it! first 4x4 tour
FORMER OWNER 2000 Black SVT #934 of 2150
#1201048 03/01/05 05:00 AM
they were a rim and tire deal for $650 couldnt pass it up. the car leveled out some after i drove it around some. i took the pics right after i put the rims on so the struts were a little out of wack. the rims i was looking at before were going to run about $600-$900 w/o tires, add some tires i would be at $1200-$1300.
#1201049 03/01/05 05:15 AM
Champagne and Gunmetal works incredibly well.
And yes, a 215 size would have made a big difference.
<--looking forward to the drop.
1992 Ford Escort LX-E -Tracer LTS spoiler -GT Grille
#1201050 03/01/05 04:10 PM
Perhapos you could sell those tires for money towards something a little thicker than a rubber band, plus those tires have to ride horribly, there's no rubber to cushion.
~Alex
#1201051 03/01/05 04:31 PM
Originally posted by SVT Driver627:
Why such a dinky tread height, those things are gunna explode when you roll over a quarter, much less a pothole.
Are you lowering it "correctly"?
~Alex
I'm rollin on the SAME size tire......No probs yet.
00SEMTXMeshgrill,KKM&K&N,Fogsmodded,17"MotegiFF5's,SilverELgauges,BlueLEDinterior,Knaubered Trubendzw/magnaflowhttp://www.sl33stak.com FSVT Smart pump
#1201052 03/01/05 04:53 PM
Q
Q
What tires?
#3162 of 6535 98 SVT Silver frost Viper Responder 791 w/ 2way remote start Let the modding begin!
#1201053 03/01/05 05:11 PM
I thought the proper size with 17s was 215/45/17. Never mind the fact that you are slowing your car down by effectively changing the gearing.....
98 Silver Frost SVT 97 BMW 540I Sport, six speed "Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future" "A coveted car should never stunt your life, but should make it more rich and interesting."
#1201054 03/01/05 05:17 PM
The problem with the 205/40/17 is much more complicated than just the ride. The main differences come in for braking and speed engineering. Any time you go above or below 3% of the total stock rim + tire diameter, you are looking for trouble. After doing the calculation, your 205/40/17 tire/rim combo is 4.13% smaller than the factory's 215/50/16, thus putting your car in a whole new world of mechanical changes.
First up is your speedometer. When your speedometer reads 62.5mph, your car is actually going 60. Your revs per mile on the 205/40/17 setup will be 886.9 compared to stock at 850.3 (engine wear & tear and gas mileage = ) About the only thing that will probably improve rather than worsen, is your braking performance, since your brakes will have less rotational area and mass in the 205/40/17 setup to halt.
Nonetheless, the aforementioned should be enough incentive for you to sell those tires and slap 215/45/17's on that baby, shich should even you diameter difference ratio to .61% larger than stock (Well inside the 3% threshhold )
XL
#1201055 03/01/05 08:18 PM
I
I
get rid of those civic size tires and get some that fit your car.
