Posts: 89 |
ack, y didn't I find out all this before I spend alot of cash on it and had it set up with a shop to be installed? all i wanted was a bit more power and faster revs.
Black '98 Mystique V6 atx. superchip,2 1/4" SVT style dual exhaust (custom) with no cat, high flow res, flo-pro mufflers with Ractive tips, 8.5" K&N conical with CTA adapter, UR Ultra Street Pulley, TH-fix. 215/45/17 Bridgestone RE730's on Konig Absolute wheels. Trans go Shift Kit, High stall torgue convertor, 24000 BTU transmission cooler.
Posts: 153 |
Originally posted by Terry Haines: Yeh...thats why I have 4 SVT's in the shop, all with bottom end 'knocks', one with a 'pulley' and no damper,two other had pulleys but were removed, one has been stock for life..all need new bottom ends!!!!!... You are the first and only person to ever say that they have a failed engine that had an UDP on it. Not questioning you - just saying that for ALL the "my engine is toast" threads on the boards here, none of them that I have read ever reported having UDP's. Are these guys of yours not CEG'rs or did I miss all the posts? BTW, how long did Brian's engine last with the stock pulley?
97 SE MTX, KKM, UR UDP, 19# Injectors, SVT TB, SVT UIM, SVT Flywheel, Grizzly Street Clutch, Upgraded motor mounts, mystifed precats, brand new main cat, SVT exhaust sans resonator, 205-55-15 Dunlop SP5000's 154hp / 156 tq before the SVT exhaust, SVT dual honed upper and swapping the mystery main cat for mystery precats. My Profile
Posts: 3,419 |
Mine lasted 86k miles BONE STOCK to the paper air filter (certainly much less than designed for), no racing, regular oil changes etc. Died from bottom end knock. I'm now convinced that crank whip killed it.
How much hp does the UDP net you anyway? Oh, and if the engine goes, it WON'T be in a ball of flame, but it will still be dead.
Why don't you just remove the air filter? It won't kill your engine immediately but it will eventually. In the meantime you'll have more power.
Posts: 1,202 |
My SE has had its UD pulley on for about 2 years of normal usage with no failure yet. The SVT has had its UD pulley since its previous owner had it installed, also about 2 years ago and still going strong. The only reason that it is coming off the SVT is because a Vortech SC is going to be installed and a DMD is going back on the crank to give the SC the proper revs it requires.
Posts: 3,248 |
You are the first and only person to ever say that they have a failed engine that had an UDP on it. Here is the problem. 1) There have been lots of engine failures. 2) Even if only a minority of them had UDPs, you cannot say UDPs are NOT part of the problem. Why, because the stock damper has been PROVEN by the OEM supplier to FAIL to prevent crank whip. Essentially, a high "background" failure rate makes it impossible to see a additional failure rate imposed by a UDP. (BTW, this is a common problem in medicical research re: disease incidence). 3) So to know HOW much worse is a UDP, you would need all the numbers....UDP failures/total Duratecs with UDPs and compare with stock failures/total stock Duratecs. Then you could see if the UDP is just BAD (same as stock), very BAD (a bit worse than stock), or VERY BAD (much worse than stock). Now, I can't say UDPs are proven to be a bad thing, but you can say that in this case based on what we know about crank harmonics in Duratec, they theoretically SHOULD a bad thing. Kind of like smoking..it shortens the average life span of a POPULATION but some INDIVIDUALS live very long lives. On the other hand, DMDs are proven to be a good thing (as far as harmonics) and they are mutually exclusive..
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 89 |
well regardless the pulley is going on tomorrow. ill see how i like it. if i do feel too much vibration it will come off as soon as i can save up for a dmd. either way im looking forward to having it on. i can always change it after. it was my mistake to buy it in some minds, but it was my choice. i should have done more research on it first. but as always im happy with the service i got from cta - top notch. and im glad i actually got replies on this. good or bad ones, i have learned. and i will report what i think if it once ive had it on for a while
Posts: 89 |
my pulley is finally on, ran into troubles getting everything in order, but its on. and you know what... i like it so far. it still idles smooth and i dont feel much if any vibration for now.
and yea a dmd is probly the best thing for our cars i can't dispute that. but im happy with my pulley for now. when you have an auto you need all the power adders you can get :rolleyes:
oh well level 10 here i come... well once i can save up enough.
Posts: 972 |
hey jay, whats up man, i havent seen you out at BP's the last 2 weeks, where you been?? there were 3 ceg'ers out at the waste managment last weekend, it was pretty cool cause we were owning all the honda boys
95 SE Champagne Mettalic True Dual exhaust with X pipe and Redline mufflers KKM Tru Rev intake H&R Springs/KYB struts Apex-i S-AFC 65mm Throttle Body 17" Ace Spades 4 Pt Racing Harness Window Tint all around New Engine @ 117k kilometers G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass" quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
Posts: 324 |
I have not had any probs with mine at all, it just did not do sh?t for any performance, waste of $ whether or not it damages your car, who knows, still a Bull**** mod IMO.
Posts: 414 |
How hard would it be to make a udp with a dampener???
98 EO #587 Currently Dirt Jumping
