Posts: 4,270 |
very nice car  that is quite an amazing work of art, and one helluva sleeper. "cocaine's a helluva drug" ~Alex
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
2000 Green CSVT gone on 2/17/06
2001 Toyota Corolla (SHE RUNS!!!)
1989 Mustang LX 5.0
Posts: 5,621 |
Originally posted by SVT Driver627: very nice car
Posts: 1,190 |
nice setup. looking good.
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese!
diamond pistons for 3.0/forsale
#702 of 2150
CEG road warrior
CEG road warrior
Posts: 17,248 |
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 2,116 |
Not to sound like a jerk or anything, but do you think that it can actually beat an EVO? Those things are quick with no wheel hop.
95 SE MTX
svt exhaust
intake
deer killer
Posts: 2,978 |
Not from a dead stop, but probably from a roll.
Posts: 431 |
Well Let see I am pushing 15 psi which is well over 400hp and EVO 285 hp I have no wheel hop since I have solid motor mounts. I have a 2.1 60 ft which may be .3 sec slower than EVO and not to mention after first gear he gains no more ground The last EVO I raced in the qaurter he ran a 13.6 at 101mph I ran a 13.2 at 107mph with only 12 psi and I had 110mph with bad launches resulting in 13.5's so let try to figure that out on which one faster and on autocross we are very even on shorter track but the longer ones Hands down are not close.
99 SVT #198 blk/blue
Spec 3/quaife/stage 2 shafts
T3/T4 fully built 3.0
ported heads
water injec./intercooled
13.2 @ 107 mph
clifford alarm and turbo timer
koni struts H&R springs
intercooler for sale
Posts: 1,190 |
what solid motor mount are you using. Do you have pics?
#702 of 2150
Posts: 431 |
I took 3/8 thick steel plate that was 3 inches wide and placed it between the mount and the frame. I drilled two holes in the plate and bent the metal strip down to the bolt running through the bushing and drilled a hole there. I passed the bolt through the the bar making the the rear motor mount solid and eliminated my wheel hop. I have the poly insert in the front too. I have no worries of breaking the shafts as much as I use too. I still have tractions problem because the last time I just went full throttle on first gear with my Azenis on the track I smapped the stage2 shaft on boost. So I am still scared of breaking another shaft but the wheels are now smooth when they are burning rubber. Wait till you get your going strong if you are near me which you should you should be able to spin both tires on boost in third gear when it hits boost at 65 mph and gain grip at 75 mph......
ported heads
13.2 @ 107 mph
Posts: 1,346 |
real nice engine bay.....hope to see that magic number 12!
E1 CSVT
s/c-----x
turbo---x
3L------check
