Posts: 9,602 |
Originally posted by supertouringmike: Originally posted by SILFROsvt98: Is getting a short shifter any different than chopping a few inches off the stock shifter?
Short Shifter refers to the length of the throw, NOT the length of the shift lever itself.
Exactly.
Some people just don't understand that point though. They think chopping the stalk is the same thing when it's not.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 4,141 |
Exactly.
Chopping the stalk DOES shorten the throw . Shortening the stalk 2 inches shortens the throw by just over an inch. i'm throwing this in here for arguments sake based solely on the coments made above.
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 862 |
I have done both in cars and I prefer the actual short shifter, not the cut stalk. Reason being is that it is harder to control the shifter when it is lower as it isn't in an optimum position for grip.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
Posts: 893 |
Of course it shortens the throws. if the shifter is shorter, the knob doesn't have to travel as far hence, shorter throws. and the positioning is fine, I've never missed a gear. I'm sure you can all justify spending all that money on a B&M but I can't.
98.5 SVT FOR SALE
$5000
Posts: 46 |
I love my B&M, I had a cut shifter in my last SVT, and it doesnt even compare to how nice the B&M throws.
Posts: 6,106 |
Originally posted by pole120: Originally posted by DemonSVT: Originally posted by supertouringmike: Short Shifter refers to the length of the throw, NOT the length of the shift lever itself.
Exactly.
I believe the only "true" short throw shifter available for the MTX-75 is the Steeda Tri-Ax(which I have). In making this a "true" short throw, the stalk was shortened ~1.5" and the lower portion(below the pivot) is longer than stock(which is why a riser plate(or in my case a lowering plate) is necessary). Having a shorter rod above the pivot point and longer rod below the pivot point provides the shorter throws as the shift cable can travel faster.
Mark
2000 Black CSVT
Posts: 893 |
ding ding ding! you are correct!
98.5 SVT FOR SALE
$5000
Posts: 6,106 |
And also, the auction appears to be a real B&M shifter. Definitely post pics for all to see.
Mark
2000 Black CSVT
Posts: 456 |
Exactly.
Makes for a leverage problem, right? Longer shift lever, more leverage.  The short shift comes from different geometry at the linkage/cable attachment point (via length/shape,etc)
01 PORSCHE 996
Merdian/Black
Full Aero
Fabspeed mufflers
Fabspeed CAI
B & M shifter
96 GL MTX Zetec 2.0
White/Blue
Blaupunkdt Houston
K & N Drop in/Koni Kit
18"RageEnduros/Flowmaster 40 Series
Posts: 6,791 |
For you guys who did cut it... what did you use? I watched my buddy do it in his escort and it shot sparks all over...
