#119838 06/07/02 03:41 AM
O
O
Has any one ever cut out the canister all toether on the pre cats and put a straight pipe in? If so how did it work and if not do you think its a good or bad idea?
#119839 06/08/02 08:05 PM
O
O
abc
#119840 06/09/02 05:03 AM
Look at a picture of the manifolds and you will see that would not accomplish anything. (actually probably worsen performance)
The manifold is designed to be as wide as the converter section.
2000 SVT #674 - Check it out!
