Page 12 of 20 1 2 10 11 12 13 14 19 20
Escape intake and mazda 6 exhaust cams is what i am running. Stop ripping on me..
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese! diamond pistons for 3.0/forsale #702 of 2150
Originally posted by svtProdigy:
HE MADE ME CUSTOM HUBS STAZI...
Listen CHILDREN!
From the pics of the actual hubs you have, they seem to be one diameter all the way down, right. Now, those new bearing you got are for hubs with a stepped diameter, 39/41mm. I bet if you measure your they are 40mm in diameter all the way from one end to the other THEREFOR the bearings won't fit/work.
Look again and tel me I'm wrong, or at least provide a clear side on pic of the OD of the HUB showing the stepped diameter required to use those bearings..
Just because they are "custom" does not allow them to defy the laws of physics.
I say.. just post your pics and go on with the build. Don't answer questions. Everyone will keep it up regardless... I think everyones just jealous. , myself included.
2006 Pontiac G6 3900SFI GTP Coupe CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint Former Owner- 2000 "Stryped" CSVT CEG Dragon Run- Oct 13-15
I'm not ripping on him. Just trying to help him avoid a serious F#$K UP!
...I think that's out of your league Stazi..
BTW Todd, I give it .5 hrs...
Ryan Trollin!
Originally posted by warmonger:
Why does the exhaust cam have the waterpump drive extension on it?
It is the intake cam on the left bank that has the water pump drive on it.
No its the exhaust cam that has the waterpump on duratecs. The exhaust cams are towards the outside of the engine..
I take everything in to consideration...I am glad you do this stazi, thanx. It will only make the car better if you give CONSTRUCTIVE and HELPFUL information. thanks brian
Ryan Trollin!
Well, was I right about the differences between the hubs you have and the bearings they supplied you or what?
dion 98 SVT, 200 whp/190 lb. ft tq (tuned by ADC), 3.0, P&P heads w/2.5L valves, optimized TB, MSDS, SCA 2.5" catback, SHOshop UIM/LIM, underdrive pulley set, TD's, Koni/H&R, BAER/TCE, Progress, CF1 products
