DemonSVT, since you are touting your "real world data" I would like to see it.
I think it is safe to assume that you do not have back to back dyno runs of your car with stock and then pinned/removed secondaries.
I looked through your website, and could only find a single dyno sheet, and a single 1/4 mile time, harldy any comparable data, which is why I would like to see what you are talking about. Some comparable before and after dyno plots would be best, or some 1/4 mile time slips run under the same atmospheric conditions would be ok too I guess (though hardly the best way to discuss an issue like this)
All I have to go on are your dyno plot and your mod list, and then compare them back to my own dyno back when my SVT was stock (alas, I have not been back to the dyno since
According to your website, you have
significantly worked your intake passages, ie extra extrude honing in both the UIM, and the intake ports in the head, as well as porting the LIM significantly. Larger, "flow-optimized" throttle body, custom calibrated 75mm MAF, large K&N filter, and moving to the exhaust, MSDS headers and Y-pipe, custom mandrel bent exhaust w/ dynomax mufflers. And then to electronics, you have an Apexi SAFC, and a custom tuned superchip (5th revision apparently).
All this leads to a dyno w/ a peak hp of 187.2 and a peak tq of 168.8
If I compare that to the dyno of my car stock (w/ a K&N drop-in filter only) all that work has netted you a whopping 26hp and 13 lb-ft of torque. Sounds like an awful lot of time, effort and cash for that small of a overall gain (and my car is certainly far from a factory freak) for someone who claims, to put it bluntly
Seems I can tune & match parts well IMO
Something ain't right here is all I'm saying, maybe I don't have all of the data, but what I can see, doesn't really support your statements Demon. Please, I would like to see any additional data you have that
does support your
real world gains.
Thanks,
Brian
