Page 9 of 9 1 2 3 4 5 6 7 8 9
Ok, I don't have the sunroof or factory keyless entry, (I got aftermarket POS system don't use it, plaining on getting new one) and you say you can make this make all the windows go down with a touch of one button with express open? and all the windows go down (on the master switch panel only not all doors?) with express open, if thats the case, I'll look into it.
Jason G. 1997 Mercury Mystique GS ZETEC ATX Born: 11/96
W
W
As long as your aftermarket alarm system can trigger the door lock/unlock outputs then you can use the remote portion and just wire it to your doors. Otherwise these window devices will work fine on any window you install them onto.
Update:
We are doing a little circuit modification right now and figure in a week or two we'll have the updates. I'll test them again and try to get us back on track.
Is this thing still on, cause my factory motor just burned out and seeing that an OEM replacement for the motor and relay was 200+ this is looking to be a little better.
You still need a working motor for this to work.
Your motor isn't fried.
2006 Pontiac G6 3900SFI GTP Coupe CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint Former Owner- 2000 "Stryped" CSVT CEG Dragon Run- Oct 13-15
then i'll have to work on it today.
W
W
It is still working guys. We are only two people and we are not as fast as when we lived down the street from each other. Everything is by mail and since I have the contour for test purposes it is snail mail slow.
Hope to have the revised devices in another week or so.
okay, thanks for the update tom!
W
W
OK, it has been a while but I haven't forgot. I have an updated windown control module here now and I'll test it soon. Still waiting on a part for the sunroof control module.
After testing we ran into a bunch of noise issues and it wasn't responding right. We had to switch a couple of parts to clean up the noise and when it comes in we will retest the circuit.
Just remember, good things come to those who wait.
Tom
Damn Tommy! Still not done?! ... thats good, I can probbaly get back in the GB now, since my sunroof should be up and running in the next coupel weeks.
Moderated by  1314_dup1
