Posts: 31 |
I just wanted to know the year model and milage and what repairs have been done. I want to see how big of a trend there is. 1 It will give us some forecasting on what to expect next and 2 we can see what Ford screwed up on.
I have a 98 se 2.5 5 speed with 65,0000 (i drive alot) I have replaced
Both front wheel bearings at 50,000 Tranny mount at 42,000 Altintator at 32,000 Sunroof motor at 42,000 Trunk Release at 42,000 Rear sway bar and end links at 42,000
Thanks for your input
Patrick
Posts: 2,961 |
93,2xx miles.
Problems: All three cats replaced (early 50's), right wheel bearing (91,xxx), tore parking brake boot (my fault, 27,xxx), rear seatbelt retractor jammed (previous owner's fault, less than 2100 mi), vacuumm hose came loose (about 10,000 mi).
That's it, except for maintenance like tires, brake pads, serpentine belt, filters and the like.
You can pillage an enemy once, but a customer is an endless resource.
James Oerichbauer - PFPC Global Fund Services
Ross: 1998 E0 SVT Contour, Toreador Red, Konis, Superchip, KKM w/heat shield, SHO-shop y-pipe and rear strut brace, no res, ScotchCal, Moda Sport 16x7.5 wheels with 205/55ZR16 Dayton Dayton tires... more
Posts: 753 |
97 SE, V6 MTX
Warranty: Main Cat - ~40k Front Sway Links (real clunk noise)- ~28k Rear Sway bar / bushing /links (misdiagnosed clunk noise)- ~27k
Non-Warranty: O2 Sensors - 49k Front Springs - 36 k (1 month out of warranty) Rubber Intake Air tube torn - 52k Leaking fuel inj. to rail seals - gas smell - ~54k
Posts: 39 |
This is a message to SVTCARBOY
How much was it for you to replace all three Cats?
Thanks Chris
Posts: 9,178 |
99 SE Zetec 48,xxx Warranty....broken arm rest. that is it. I love my car!
Posts: 559 |
51K 100 miles+ per day - 0 problems
99 SVT Black/Tan #1090/2760 82K Miles.......B&M Edge Shifter Mobil1 5-30.....Side Markers Ford Synth MTX # XT-M5-QS Locking Lugs....Cup Holders Black Sail Panels...TH Fix Aluminum Gas Filler Door BS Potenza S-03's KVR Cross Drilled Rotors + Pads Dual Mode Damper - soon Clarion head unit Pioneer 2-ways
Posts: 200 |
98 SE V-6 ATX: 56K miles
Airbag control unit crapped out at about 30K - replaced under warranty. Otherwise, runs like a Rolex, despite autocrossing and horrible traffic.
*** Sidewinder: 1999 SVT Thud: 1998 SE V-6 Edgecrusher: 1998 Mercury Mountaineer, 5.0L
Posts: 529 |
55k and change...zilch!
Gotta love that Zetec!
Andrew Morris \'99 SE Zetec ATX All of life's big problems include the words "indictment" or "inoperable." Everything else is small stuff.
Posts: 7,329 |
15k miles... Been to the dealer for the sunroof over a half dozen times. Fixed it myself in one try (KNOCK ON WOOD) with some good advice from this site last summer.
It's still prone to melting/stripping the plastic gear though. No fix for that yet (Hightower???)
The paint (clear coat actually) on the front bumper is peeling. I got it repainted once (free at the dealer) and it didn't help...
Otherwise it's treated me very well...
Posts: 1,537 |
65k miles and still going....
It's all in the Signature.
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
