The little rocker sill on my rear driver side is loose, and i wish to use a floor jack to lift the rear end off the ground, and to gain access to area around the wheel arch. Since im not a complete noob, i did some research, and found a post:
" You should have no problems jacking up a stock SVT, hell mine is even lowered and I have no problems. I use a floor jack. Just take out the inserts and roll the jack underneath the car. Right behind the skirt is a metal seam that has a groove cut into it. Jack it up by that seam. Then put a jack stand on the seam and remove the jack. " (JonnySVT)
Sounds pretty good, but i was just wonderin if you guys could confirm that.
Thanks for the help
