Page 2 of 2 1 2
checked the code list and it means cyl. #1
The cylinders that had oil in them were 3, 5, 6.
So Im thinkin plug #1
What you think?
Misfire is cause dby lack of fuel, spark or compression
raw statistics suggest a 1/3 chance.. lol
Yeah.. get the Autolites and ditch the Bosch's.
Ray
sorry to bring this up but I would like to knwo if you fix ur computer because it's very simliar to my car ... le tme know thanx
F
F
I would replace the sparkplug wires, and maybe check compression on the cylinders. The plugs will be wet if not firing. Here is a firing order diagram, worth checking. Sort of tricky to read, but the best one I've seen:
[image][/image]
I have in past had cylinder 2 misfiring from a carbon track on the plug, and bad running from miswiring the plugs...
Good luck with getting the smooth running back again. Patience (and spare cash) help a lot!
thank you for the diagram, I will run a compression test as well as change out a set of new plug and see the different...THANX
F
F
You're welcome, hope the solution is easy and affordable
Page 2 of 2 1 2
