Posts: 4,141 |
bump....2 in stock
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 3,570 |
Hey pole, when are you doing fronts?
Posts: 4,141 |
i'm doing them one at a time right now, as i only have one core in circulation, Stazi has it at the moment, once i get his back i'll be able to do another.
Pole
Totaled 02/12/06
Posts: 4,141 |
update guys:
i have 1 rear mount done ready to ship
and three rear cores that can be filled the day an order is placed.....
thats 4 mounts that can be out the door in 2 days.....
Totaled 02/12/06
Posts: 1,593 |
I just got my poly rear roll resistor yesterday ! Looks AWESOME ! ! ! I hope to install it this weekend !
Pole please let me know when you might have a front available.
Any tips and tricks of the pros? Any suggestions from those that have replaced it?
MUST SELL - ECM computer new for a 98 V6 mtx + pats
Now trolling in a Red Nissan 4 x 4
Posts: 6,791 |
Hit the bolts with some PB blaster, NOW!!! Trust me, you'll be happy that you did. I broke one of the bolts, and had hell getting the broken portion out of the nut material. And finding the oddball fastener was not easy either, Ford wanted about $20 for it.  Other then that though, the install is simple. The only thing that stuumped me for about 23 seconds was when I was putting the new poly on, that the through bolt did not match up with the hole. I jacked my trans up, enough to line everything up and was done!
Posts: 4,140 |
I just got my GCs and Konis on, and now that that end of things is under control, I can feel the roll resistor much better. Let me state this clearly: I cannot induce wheelhop. I tried. I left rubber all across the county. Zero wheelhop. Man, does it feel good! Thanks Josh! Oh, and this hot weather makes the NVH gremlins dissapear. At -20 degrees F the poly is much more prone to shatter my teeth
Posts: 1,593 |
Originally posted by Auto-X Fil: I just got my GCs and Konis on, and now that that end of things is under control, I can feel the roll resistor much better. Let me state this clearly: I cannot induce wheelhop. I tried. I left rubber all across the county. Zero wheelhop. Man, does it feel good! Thanks Josh!
I'm now wondering whether this part is a mistake for me? I don't care about wheel hop, and am not interested in adding vibrations (NVH) to my car. This is my daily commuter/ only car.
I was just thinking these poly resistors were a less expensive way of replacing some of the motor mounts (stock new resistors are like $180) that my mechanic said I needed soon.
Any input? I am not a racer or anything. Just want to keep my car running for the next 100K miles.
Posts: 4,140 |
If you have never had wheelhop, just get the rubber kind from Bill @ sig LM, and ship your core to Josh. If you get wheelhop in the rain/snow then this will help prolong the life of your diff.
I exaggerate slighly about the NVH, but it is pretty bad in very cold weather.
Posts: 4,141 |
NVH is not that bad, especuially in warm weather, and, houghh you will notice it right after install, you grow accustomed to it in a short time, and hardly notice.
Totaled 02/12/06
