Posts: 62 |
Mobil 1 5-30 the only way to go.
96 Black SE 2.5L V6 ATX
Posts: 7,329 |
Originally posted by breidy: 0-30 in miami = poof!
05-30 Mobil 1 Synth "In miami's winter" 10-30 Mobil 1 Synth "In miami's summer" All 3 have the same weight at operating temps. None would protect any better than the other with the lower "initial" weight multi-grades even flowing a little better at startup.
Posts: 1,375 |
Originally posted by SilverbulletSVT1: I would recommend Mobil 1 5w30 full synthetic. It is what I use and I love the stuff. They just came out with Mobil 1 Super Synthetic also, can't wait til my next oil change to try it. Mobil 1 is what Ford recomends for most of their high performance vehicles and it is what is also used in quite a few race car including some formula 1 I think. Whats the deal with the new super synthetic? There is N/P with changing from mobil 1 full synthetic to the new stuff because i already did  and haven't had a problem
99 SVT Tropic Green #151 of 503/ 2760 total Born on 10/07/98 Adopted 7/15/00 LETS GO RANGERS (looking good this year)
Posts: 852 |
All 3 have the same weight at operating temps. None would protect any better than the other with the lower "initial" weight multi-grades even flowing a little better at startup. True, but if you are gonna stretch your oil over a few more miles, my money is on the lower spread oil to keep its rated warm viscosity the longest. Thats why i don't use 5W30, even in Canada. Might consider it in winter, but not in summer.
Marco Tatta 98.5 SE MTX, Duratec EGR block, fog light fix, custom shift boot, monsterflow intake, Ecotek valve Quasi dual cardoctor exhaust. Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
Posts: 3,636 |
There is some concern that a wider range of viscosities results in an oil that is more viscosity improver (VI) and less "oil"
VI doesn't lubricate the engine, it simply allows the oils viscosity to change as temperatures change.
So, one could make a good argument for a 10W30 in the summer and a 5W30 in the winter. So at least with conventional (non-synthetic) oils, you get more lube and less VI with the 10W30, than with the 5W30 oil, as there is more viscosity spread in the 5W30 lube.
I was pondering, what issues, if any, there would be with a SJ or SL rated straight 30 oil in the summer time. (I'm not talking about 30ND that was used by my grandfather, either.) You still have the additives that protect against acids and what not, but don't get the VI stuff. A bit more lube in your crankcase.
Anyone want to comment on this?
TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 3,419 |
One of the nice things about Mobil 1 Tri-Synthetic 5W-30 (dunno about the new SuperSyn) is that it doesn't use any VI to achieve the 5W-30, at least from what I've read.  So, I doubt the viscosity spread in that case is much of a concern. When considering an oil with VI, you want to choose the lowest spread possible to minimize the VI in there, as has been noted. For Derek D., I say use the Mobil 1 5W-30. It's what I put in mom's 01 ZX3 (screw that 5W-20 stuff). However, if you ask 10 people around here, you are probably going to get 10 different answers, so don't expect anything definitive. Just like if you were to ask what car polish/wax to use ... :rolleyes:
Posts: 491 |
1997 GL Sport MTX, Soon to be the fastest proven Zetec around.
Posts: 517 |
2000 SVT (silver) #1529 of 2150 ------------------- yeah...its modded
Posts: 7,329 |
Originally posted by Sleeper: Castrol Syntec 5W-30 Syntec is not a true synthetic (waste of money) It has extremely high amounts of ash content (becomes acidic) Has "active particles" that seek out and wrap contaminents. (read - more crap floating in your oil that shouldn't be there & making the contaminents in your oil Bigger!) I'm surprised by the fact that Castrol makes a very good conventional oil and then makes junk for a pseudo synthetic... What were they thinking!!! :rolleyes:
Posts: 460 |
I am currently using Redline Synthetic oil. Some say that I wasted $50, but I don't think so. I am in the devil's land, here in Phoenix and it gets f'n hot. It is supposed to be the best oil made, bar none. I hear that Amsoil and Royal Purple have products that come close. The better oils have longer change intervals. I heard someone say that you can run Redline for 50k miles... I would't try it, but I will go over 5k. The oil debate might as well be Theology... Some people swear by Valvoline, but I wouldn't lube my lawn mower with it.
Po-Jay
Ghetto Mods Galore! Quaife-CenterForce Clutch-Butterflies Rmvd and Replaced again-Bassani Exhaust w/custom "Y"-Pipe-33% of Mystery Mod-Pro M 75MM MAF-BNoon Optimized SVT TB-B+M Short Throw-ES Front Engine Mount-Some Aesthetic Crap- Blood,Sweat,Tears Do I hear the Fat Lady singing? 98 E0 Silver Frost (Is there any other color?) 172HP 149TQ W/Bad A/F Mix
