#119547 06/01/02 08:39 AM
SVT9801 Offline OP
i want a bigger TB and i noticed that the 4.6 mustang TB on some SVTs so i was wondering what all is involved in making the TB fit the 2.5 v6 and where i could get one
1998 Toreador Red Svt #3486 0f 6535,fader window tint,JVC El Kameleon KD-LX100,JSP
touring wing,resonater removed,cleared corners,door dings removed,omp strut tower brace
#119548 06/01/02 11:57 AM
I have one, but am by no means an expert. My friend did it so I figured I'd do mine also and he could help. I bought the stock 65mm 4.6L throttle body from a 98 GT. We had to unscrew the butterfly and then pull out the place where the throttle cable connects and flip it around. (Wishing I had a good close picture right now) Then, we had to file down some of the plastic to make the cable run smoothly thru it.
I got mine at www.dfwstangs.com. Just find a mustang board and put a post out there that says, "Anybody who has upgraded the TB on a 4.6L mustang and wants to sell me their old one for $40 or so, let me know." I had mine in 24 hours.
Good luck!
1998 T-Red CSVT (1492 of 6535)
Born on 5/30/97
KKM
4.6L TB with custom "Throttle Optimizer"
Bassani Exhaust
NP-Tuning Sniper Intake Pipe
Fog Light Mod with 885's
Clear Corners
Stereo - Oh Yeah!
GOLIATH - RIP 6/14/02
#119549 06/01/02 05:31 PM
N
N
Is there anything else that needs to be done for this to work on an SE? I thought I heard stuff about needing better control of air/fuel, i.e. apex-i or the like? I wanted to go with a larger TB myself but that talk scared me away, anyone care to comment?
~Shawn Clone~
1999 SE Sport V6 MTX
Silver frost/Midnight Blue
BAT Euro Handling kit, SCA Cold Air intake, painted dash/calipers, Elky's mesh grille, bulitt fuel door,B&M shifter, ES motor mount inserts, OMP front strut tower brace, newest mod- HPP rear strut tower brace ...coming soon, Aussie Bar
Possabilities in the works: Custom CAI, Polished stainless shifter cover plate
#119550 06/02/02 02:06 AM
I'm not real familiar with the SE setup. From what I understand, upgrading to a CSVT throttle body made quite an improvement.
Born on 5/30/97
KKM
Bassani Exhaust
Clear Corners
Stereo - Oh Yeah!
#119551 06/02/02 09:11 PM
What kind of Gains did you get from the new TB?
Black '98 Contour SVT
#162 of 6535
-Indiglo Gauge cluster-
-Kenwood KDC-X815-
-Audiobahn ALUM12x sub-
-Audibahn 18001d Digital Amp-
-Audiobahn 1.0 farad cap-
-LED side markers/washer nozzels-
-KKM Intake - Bosch Plat. +4-
-Custom Exhaust - NO res.-
-Sho Shop off road Y-pipe-
-Fog light fix - THX-Fix-
-Koni strurts - Roush springs-
#119552 06/02/02 09:36 PM
make sure you have enough air coming in to support that large of a TB, remember intake velocity is imporant. (Otherwise we wouldn't have secondaries right? :p ) Secondly make sure you are getting that air out. My suggestion is to go with an SVT TB and once you do a 3L swap or something drastic then go bigger. Im running an KKM, Aussie pipe, Optimized SVT TB and ST2000 upper intake manifold and a SHO Y-pipe on the back end and my SE runs like a scalded dog. Im going to miss it, my best friend is buying it next week. At least it will be around for me to drive occasionally
98 V6 Lots-o-mods SOLD
88 Daytona Shelby Z TII (The beast)
87 Daytona Shelby Z TII (Holy 20 psi of boost batman!)
Mods- 3" Downpipe, Hi-Flow cat, 3" mandrel bent exhaust with Dynomax Ultra flow. Manual boost controller, TurboXS blowoff, 5th injector, large canister wastegate, Nitrous Express go-fast-be-happy kit, ported exhaust manifold, ported intake manifold, upgraded motormounts, eibach springs, strut tower brace. Oh and 20 PSI to boot.. my oh my...
#119553 06/03/02 01:59 AM
E
E
I just finished installing a honed UIM and new 60 MM throttle body and used SVT airbox on my 96 SE V-6. The honed manifold plus the cleaning I gave to the lower manifold made a noticeable performance difference. I used my original 54 MM TB. for a few weeks before I installed the SVT equipment.I was disappointed in the sound of the SVT air box, it sounded like the stock Duratec setup. I removed the fender to airbox adapter (Hose) and now it sounds good and seems to perform better when you get on it.
One tip I'll pass along is if you do a cleaning to the intakes and the mileage/age of car dictates, now is the time to change the water hose from the water pump to the engine block. The hose wasn't in stock at one dealer and is expensive, so I would order one from Bill or the other CEG dealers ahead of time because it looks hard to reinstall a new one with the UIM in the way.
