Page 2 of 3 1 2 3
Uploading now...
Originally posted by SVT Driver627:
my fogs are soo dammn bright that I pretty much have 4 driving lights . And its bright I tell ya
Pics? come on, it's your turn now.
~Alex
give me 10min, I'll make a new thread and post pics
So I just went outside to change up a few things. First, I replaced the Philips with a Silverstar modded highbeam bulb in my lows. I then attempted to get the same aim on each. I am sure you can notice the passanger side is the new assembly. Also note the fact that the old is hazy and aimed a little higher. This gives it what seems to be a brighter light when looking straight at it. The hot spot does indeed seems a little brighter on the new lamp but I remember it being a little less structured when I was driving it. (Factory has a nice rectangle it puts out). Also not the new KYC seems to have this striping effect closer to the car. Not too sure what is causing that. Fogs I assume will flood that out. Enough of my babbling, here are the visuals.
weird, your patter in circly. Mine are rectangular..hmm
Read the post, they are indeed rectagular. They are shining of gravel and not the most level ground in the world. Up on a wall, they will be rectangles the Ford moreso than the KYC.
Ok, as I mentioned I got my new headlights installed this morning, very happy with the results:
They came with Philips high & low beams, but not the turn signal bulbs. I had some decent Sylvania (not Silverstars, but they were like $20 each) bulbs in my old headlights, but the lows were 51 watts and highs were 60w, versus 60w and 65w for the new Philips ones, so I used the Philips.
Old & new lights together:
For those who haven't changed headlights on a Contour, the only tools you need need are a big straight screwdriver for the mounting bolts, a philips screwdriver to put the lower brackets on the new headlights, and Torx-20(?) if you want to tackle aiming the headlights. I'll still get them properly aimed at a garage.
Took about an hour. It seemed impossible to get the connectors off the turn signal bulbs without breaking the little tabs:
The fit is 95% good as original. The only part I don't like is the black round rubber trim on top, it sticks out a little and doesn't quite meet up with the flat rubber trim:
I might dummy something up to seal that area better.
Big before shot:
One new, one old:
Both new:
Wish I'd have taken a night shot before I changed them so I could before & after night shots.
That's all. Easy to do and makes my Contour look new again!
98 Contour V6 MTX, T-Red, 150k mi. Pic SVT Dual Exhaust, KKM Intake, Donnely Mirror, Dension DMP3 Player w/80GB of MP3s, Wheelskin 95 F-150 91 Mustang GT 06 Honda Shadow Aero
u lucky son of a ....
those fit peeeeerrfectly!!!
dammn u depot! dammn u to hell!!!!!
what are you doin with your old ones?
~Alex
I think Quick_SVT is going to get them, if not I'll let you know.
LOL, sorry sorry. But you have a SVT and I don't.
Page 2 of 3 1 2 3
