Posts: 5,805 |
'Matt'...its an abrasive 'slurry'........
Posts: 1,444 |
hey i just met leo capaldi over the weekend at limerock park. took a bunch of pics of his car. he got ford to make him custom cams. was cool to see an svt engine in the cougar.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 1,861 |
In a way, you might say that the SVT already has a mild port and polish job. That is sort of what the extrude hone process does, without making the surface too smooth.
There is more art than science to porting. Things that work on one engine design may not work on others. It is largly a trial and error process. If you are an amatuer, it is best to stick with matching ports to gaskets and only very mild polishing and perhaps the very lightest of work in the valve bowls and multiple valve seat angles.
Jim Johnson 98 SVT
Posts: 5,805 |
Big Jim...agree, but dont mess with valve angles etc unless you know what you are doing...the best shops for this have experience in multi valve heads re Cosworth etc..
Posts: 115 |
Leo Capaldi gained 123HP at the crank with the following mods
No Emissions (none whatsoever) No secondaries Full port and polish done on both intake manifolds (upper intake was cut in half lenght wise, ported then rewelded - lower intake siamesed to match new upper ports) Full port and polish done on heads Much higher fuel pressure and larger injectors His ECU was also flashed to accomodate the new air and fuel
mind you he also has much stronger internals, but they don't add power, they just make sure it doesn't break....
so does port and polish help the engine? sure if you have 25K+ to throw to a "Highly qualified" engine builder, with a few spare engines cause you will undoubtevly break a couple on your way there.
2000 Cougar V6 MTX Black Visteon GFX Kit with Razzi rear skirts, Ground Controls, YoDude Exhaust, Ractive Filter, Custom Interior, Custom Loud Stereo, and more... See Her Here
Posts: 142 |
i met Capaldi at the Ford HQ FME open house a month or two ago. he got lots of horsepower through cam work and raising comp. ratio to around 13:1. I also got to sit in his car  i have some pics on my HD but not on a url so i cant post them...
-1988 Bronco II: Blue and silver with 8 shades of rust. The system costs more than the vehicle  -1999 SVT Contour: Silver Frost, tinted windows, stock for now... -------- "Never slap a man that's chewin tobacco"
Posts: 244 |
Not to be picky... but I think the term you're looking for here is matte. --JamesT
>--------------< --Chemguru
99 CSVT Frost /Mid. Blue
00 Suzuki SV650 Red, Naked
Posts: 4,476 |
Originally posted by chemguru: Not to be picky... but I think the term you're looking for here is matte.
--JamesThehe - Terry's probably using the British spelling  :p
Todd Christ SVT Contour Registry MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator '98 E0 SVT Contour #1037 of 6535
Posts: 5,805 |
matt...dull,lustreless, not shiny...'Collins ENGLISH Dictionary..1989 Edition..(page 328)...buddy!
