Posts: 3,076 |
My car is in the dealership now getting its clogged pre-cats replaced under warranty. I just got a call from the service manager saying that they ordered the WRONG pre-cats??? Aparently the SVT have high flow pre-cats and they ordred the regular contour version??? Is this true, I thought they were the same thing. I just want to make sure Im not getting the runaround.
2000 SVT Black/Tan #1633/2150 (a few mods)
Alpine: CDA-9835, MRV-F540, MRD-M550
PG: TANTRUM-X 6.5 COMP all around.
Some people wear Superman pajamas. Superman wears Chuck Norris pajamas.
CEL currently: Off
Posts: 1,356 |
I know the main cat is 2.25" as opposed to the regular one which is 2". Im not sure if the precats are different or not. I always thought they were the same...
I guess its possible that they are different...
1999 Mystique LS V6
Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
Posts: 9,602 |
Originally posted by CarpePoon: Aparently the SVT have high flow pre-cats and they ordred the regular contour version??? Is this true, I thought they were the same thing. I just want to make sure Im not getting the runaround.
You are getting the run around.
The pre-cats are the same.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 3,076 |
I spoke to them again, aparently its standard procedure to replace all the cats when there is a warranty issue. So they are replacing the Main cat as well. So am I still getting the run around?? Its all not costing me a cent.
CEL currently: Off
Posts: 6,106 |
Definitely the same.. If they're replacing your main cat also, they could be waiting on that, as the SVT cat is higher flowing than the standard Duratec.
Mark
2000 Black CSVT
Posts: 96 |
Why worry about the pre cats...when you put on your headers you'll be removing those anyway....if you are serious about performance...you will put on headers....sooner or later...
99 SVT (Black) # 2642 of 2760
So Many Mods...So Little Time!!
