#1193645 02/21/05 07:32 PM
My car is in the dealership now getting its clogged pre-cats replaced under warranty. I just got a call from the service manager saying that they ordered the WRONG pre-cats??? Aparently the SVT have high flow pre-cats and they ordred the regular contour version???
Is this true, I thought they were the same thing. I just want to make sure Im not getting the runaround.
2000 SVT Black/Tan #1633/2150 (a few mods) Alpine: CDA-9835, MRV-F540, MRD-M550 PG: TANTRUM-X 6.5 COMP all around. Some people wear Superman pajamas. Superman wears Chuck Norris pajamas. CEL currently: Off
#1193646 02/21/05 07:36 PM
9
I know the main cat is 2.25" as opposed to the regular one which is 2". Im not sure if the precats are different or not. I always thought they were the same...
I guess its possible that they are different...
1999 Mystique LS V6 Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
#1193647 02/21/05 07:54 PM
You are getting the run around.
The pre-cats are the same.
#1193648 02/21/05 08:20 PM
I spoke to them again, aparently its standard procedure to replace all the cats when there is a warranty issue. So they are replacing the Main cat as well. So am I still getting the run around?? Its all not costing me a cent.
#1193649 02/21/05 08:21 PM
Y
Y
Definitely the same.. If they're replacing your main cat also, they could be waiting on that, as the SVT cat is higher flowing than the standard Duratec.
Mark
#1193650 02/28/05 01:52 AM
Why worry about the pre cats...when you put on your headers you'll be removing those anyway....if you are serious about performance...you will put on headers....sooner or later...
99 SVT (Black) # 2642 of 2760 So Many Mods...So Little Time!!
