Posts: 100 |
Just something to think about, exactly how does your PCM know what load your engine is running at if you are tricking the PCM to think you are still using a stock maf?
Also, look for a maf that will read accurate for the amout of CFM you plan on pulling. The Ford 80 mm and 90 mm are among the best curves I have seen, but I have yet to see them all. Rara what is your opinion on this subject?
14.6 out of a 12 valve 3.0 Taurus A wise man once said, rather then watch a girl wrestle I would rather see her box.
Posts: 3,419 |
Originally posted by Jason King: Just something to think about, exactly how does your PCM know what load your engine is running at if you are tricking the PCM to think you are still using a stock maf?
The biggest limitation and compromise of MAF trickery (whether it is Optimizer, S-AFC, MAFturburner, or whatever). MAF voltage is used in the load calculations, and load is used to determine proper spark timing. A good article explaining the relationship (from a Mustang site): Read Me!
Posts: 308 |
Still no reply from Muscle Motors, I have emailed them 3 times now once each day to see what I have to do. I don't want to just send it back to them without them authorizing it because then it may just sit on some shelf. I am getting pissed!!
99 SVT Green/Tan #44 TH-Fix, Aussie Pipe, PRO-M, SHO-Shop Y, Borla, and other Misc. 93 Tracer LTS Eibach, K&N, Misc (now my winter beater) email me: keith@thinkingcapdesign.com My Car: http://www.thinkingcapdesign.com/KeithsSVT/
Posts: 1,812 |
Bummer Kieth. I'm sorry to hear about the crumby situation.
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 331 |
Originally posted by Derk2000: Bummer Kieth. I'm sorry to hear about the crumby situation. Derek, just to let you know I've had my Pro-M (from your GB) installed for a couple weeks now and she's running glitch free.
[[Justin]] '98 Silver Frost SVT #2089/6535 I am made of cheese My car is in the shop When I drop the clutch, I get wheel hop Do not eat me, oh please
Posts: 308 |
Got the OK today to send it back to MM
Posts: 1,812 |
Hey great, Kieth. I hope it works out for you. /knock on wood/ FYI, Mine's working well so far.
Posts: 324 |
Why does everyone keep buying these things, not worth it, just like UDPs, if they do anything at all, it's not much
Posts: 2,848 |
Did you guys even rear RARA's post about the pro-m? These things are no good....and can cause engine damage in the long run. Not a good idea unless you've got someone tuning your maf for you and a chip. Turning that dial doesn't cut it.
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 308 |
I am not sure? I read a topic someone posted on how running the engine lean can affect it in a harmful way, that is why I didn't want to mess with trying to figure it out on my own. I sent it back to be recalibrated. If you have the topic handy, post a link to it.
Trinity, every little bit of HP helps out, unless you have the cash for a Supercharger or the Turbo right away.
Thanks!!
