#119268 05/27/02 03:02 PM
V
V
After installing new plugs is it necasary to reset the computer. might be a dumb question,just curious.If yes then how do I reset it.
VTEC THIS
98 CSVT, 17" Focal F5's, Blue sidemarkers/Hyperwhite Headlights, Dynomax Bullet Resonator , Bosch Platinom +4's plugs , K&N Drop in
#119269 05/27/02 03:33 PM
To reset the computer alls you have to do is either pull the negitive battery cable off and let it sit off for a few minutes so it clears the memory or you can go into your power distribution box and pull fuses #4 and fuse #11 and leave out for a few minutes. Hope that helps.
