When I worked at Jiffy Lube, I did the tranny flushes and it only took me about 20 min or so and the fluid flowed clean. The machine just hooks your tranny up to a bigger fluid reservoir that your trannys oil pump pumps though itself and pumps the old fluid into a seperate reservoir. The reservoirs are in the same cylinder but are seperated by a piston.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
