#1192642 02/20/05 09:10 PM
2
I went to Midas yesterday to get my tranny flushed and it took them like 20 mins to do becuase they jkust got a new flusher like a week ago and i'm kinda worried. I paid 99.95 for the service and I hope the machine actually flushed out my tranny. What do you guys think. Do you think I couldve done better? Thanks in advance.
Irfan Rahim irfman2000@yahoo.com 2006 Blue Nissan Sentra SE-R Spec V Former owner of a silver 2000 Contour SE Sport ATX
#1192643 02/20/05 10:13 PM
F
F
You could have done it yourself in your driveway with the help of a friend for less than $40
#1192644 02/20/05 10:35 PM
If it was truely flushed then you generally did a good thing...as long as the valve body is not worn out!!!!!
Before I had min flused I did a drain and refill 3 times to try and clear the old fluid out. Even after I did this, I then went to have a power flush done and their was a good portion of the fluid that was very dark! Of course I power flushed after I installed the Shift correction kit.
Bob
#1192645 02/21/05 02:46 AM
How does the fluid look? That's the main way to tell how well it got flushed. Twenty minutes does sound a little short do do a complete flush, but it is possible, depending on the machine and how well the operator has been trained.
#1192646 02/22/05 01:03 AM
2
Well it was their first time using it ever so I dont know what the hell they did. The fluid seems to be a little gritty but it doesnt smell burnt so maybe it is flushed. Plus I didnt want to do a drain and refill 2-3 times. its too much. I'd rather do a one time flush and thats it. At 55k I did a drain and refill but not since then until last sat. I got 87k on it now and I know how the CD4e's are and I hope I can get 140k+ out of it.Maybe at another 20k ill do the flush again to ensure that the fluid is out.
#1192647 02/22/05 01:22 AM
9
When I worked at Jiffy Lube, I did the tranny flushes and it only took me about 20 min or so and the fluid flowed clean. The machine just hooks your tranny up to a bigger fluid reservoir that your trannys oil pump pumps though itself and pumps the old fluid into a seperate reservoir. The reservoirs are in the same cylinder but are seperated by a piston.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
#1192648 02/22/05 03:32 AM
CEG road warrior
CEG road warrior
I have had my tranny flushed like 4 times already. Took about 30 mins at Jiffy Lube.
