Posts: 7,025 |
mikey boys true duals run underneath the gas tank. My exhaust for my turbo setup runs underneath the gas tank as well.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 46 |
Posts: 6,106 |
Originally posted by bnoon: Originally posted by getlucky151: Get the true dual set up. I have it on my csvt right now, and it sounds great! They bend the pipes around the gas tank...not under.
Under the tank is better. It eliminates 3 bends from each pipe. That also equals a shorter distance traveled for each bank too. It took Demon's design to convice me of this routing and I didn't believe it until I saw his pics, otherwise my tru duals would have looked like his...
Oh and H-Pipe, not X-Pipe.. Figured Demon would have gotten on getlucky151 about that.
Mark
2000 Black CSVT
Posts: 46 |
Originally posted by Y2KSVT: Originally posted by bnoon: Originally posted by getlucky151: Get the true dual set up. I have it on my csvt right now, and it sounds great! They bend the pipes around the gas tank...not under.
Mark
Where does the H-pipe go when running under the tank?? Also how many mufflers would you run 2 or 4, or 2 mufflers, 2hi-flow resonators..??
Posts: 363 |
Whether X or H, place it as far forward as convienient. The sooner you start to balance the pressure in both sides of the exhaust, the better.
98 Mystique GS V6 - K&N, projectors
91 Mustang LX 5.0L
00 Jetta TDI, Yay, I bought it !!
95 VW Getta TD - RIP: Nov.3,2005
Posts: 6,106 |
Take a look at DemonSVT's website. He explains everything down to the nitty-gritty. It's definitely a great reference tool for people doing ANY of the mods he's performed. I can't tell you what his car sounds like with that setup, but can assure he's reached it's full potential in exhaust flow with his, dare I say it, anal(and I say that in a good way  ) attention to detail. Mark
2000 Black CSVT
Posts: 638 |
I know that multiple people have duals under the tank, but if you have to drive in snow and/or over speed bumps, how does it work with lowered suspension.
87 Mustang GT 5.0L TURBO
Posts: 9,602 |
Originally posted by Pope: I know that multiple people have duals under the tank, but if you have to drive in snow and/or over speed bumps, how does it work with lowered suspension.
My exhaust pipes have more ground clearance then my side skirts or lowest points of the front bumper.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 638 |
SWEET!!!! that is what I was hoping... that makes things so much simpler.
Posts: 4,155 |
Before the Trubendz, I wanted to build a true dual setup UNDER the gas tank, but thought better of it because I didn't want it bottoming out, or causing a problem with the gas tank itself. Well, now 650 dollars later I know what I COULD have done!  Meh, Im totally happy with what I have
