SHO Y, peice of CRAP!!!I got mine and guess what instead of gaining I loss a tenth in the 1/4 and about 1mph. Worse part, I bought the Stainless Steel Y, and those *******s have the nerve to weld in a piece of regular steel piping on the Flex Pipe, DAMN thing is rusted big time and it's only been on there for about 3months. There Y design is High School developement at best, in fact with all that flashing in the pipes from welding (hopefully you have a Dremel) you're lucky if you even get anything from there system. A few may have been lucky with the Y's, but I'll tell you my thoughts, from what I've been recently sudying, there Y is very poorly designed and put together and those factors alone should help keep you away from purchasing 1. My suggestion, Optimize your stock Y, swap out for a higher flowing CAT and install a good catback system Bassani or something if you're looking for a Cheap route.
Personally, I have extreme plans on the exhaust side. My exhaust system will be computer developed to perform optimally for my motor, dimensions, length and so forth. If you seen the Y I'll be putting on my car, 'You'd probably end up Vommiting,' all over SHO's Y that is.
Sorry but I can't explain the details of the exhaust, as I'm working on possibly providing this to the Contour Public and so details are confidential at the moment, Plus I'd like to be the 1st to have it if you know what I mean!!!
