Originally posted by left-lane louie: Nothing? Nobody? OK. If its not a shaft seal leaking what else could it be? C'mon y'all. LLL
Where's it leaking from?
There are axle seals that can leak, those would be relatively easy to fix. There should also have been an o-ring or rtv put on the back of the throw out bearing - if that was missing I'd guess youd get some "splash" leak into the bellhousing area.
Also oil coming from rear main seal will leak at the tranny to engine mating point.
97 Contour SE MTX
04 Grand Caravan SXT
