Page 2 of 3 1 2 3
That depends on whether you buy into the reverse cone idea or not. I personally like my reverse cone S+B Big Mouth, but others have complained of turbulence issues. The reverse cone filters tend to whistle much more (at least mine have). I believe that this is common, right (anyone)?
Po-Jay
Ghetto Mods Galore!
Quaife-CenterForce Clutch-Butterflies Rmvd and Replaced again-Bassani Exhaust w/custom "Y"-Pipe-33% of Mystery Mod-Pro M 75MM MAF-BNoon Optimized SVT TB-B+M Short Throw-ES Front Engine Mount-Some Aesthetic Crap-
Blood,Sweat,Tears
Do I hear the Fat Lady singing?
98 E0 Silver Frost (Is there any other color?)
172HP 149TQ W/Bad A/F Mix
OK, looking at that pic it looks like SHO-Shop is using the same K&N that I am (though mine may be a bit longer?). Anyway, I can say that on the dyno the K&N was worth 1-2 HP over KKM (with both in a custom cool airbox) but only between 6K and 7K RPM. Not likely to notice that difference but since they are throwing in a heat shield for the money I would favor the SHO-Shop intake. No reports of K&N collapsing at high RPM (like KKM) either.
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
Has anyone proven that the KKM actually "Collapses" from suction? I truly believe that it is the pressure on it from the fender well and the MAF. It is being crushed between the two. If the filter dose not contact both sides, it doesn't crush. I am thinking IMHO that it would take more than a mere 180 FWHP car to implode a conical filter... ($0.02)
Po-Jay
Ghetto Mods Galore!
Blood,Sweat,Tears
im going to be gettin the sho shop cold air intake just in time for the summer laugh
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
I saw it first hand on the dyno.
I have a nice dyno graph to prove it. wink
2000 SVT #674 - Check it out!
Okay, here i am again. I considered both the KKM and sho shop cold air. Even the BAT with the remote air intake. I was actually going to go with the BAT, but i noticed it is a little too pricey for me. So i then compared the sho shop, and the kkm. I then just realized i might as well go with the sho shop because it has a heat shield. Only because i don't want any future problems with heatsoak. I mean heatsoak shouldn't be too much of a worry, especially since i'm always moving on the road, but it was a just in case kinda thing. As for the KKM, i really didn't think that even though it was closed at the fender would make much of a difference if it was closed or not. And as i said, performance numbers isn't what i wanted. It was more like a save in gas. Just my .02.
by the way, there is a slight kick than what i used to have. Not much of a difference, but it was enough to be noticed. Especially with over 400 lbs of added weight in my trunk.
Give me more beer and CEG before i get depressed!
AIM/AOL: DBZ Jr
black_98.5_SVT, you made a decision yet? laugh wink
I'd say the ShoShop setup is a good one, but their service (so I've heard) is less then one would expect.
2000 Silver SVT #1602
Check it out in the registry!
Mi Coche
I have the SHOshop and I love it. I would say get it. The heat shield is an obvious advantage and also you get a great sound if thats what you're after. It's an easy install too. Let us know what you go for.
><>David<><
"this world has nothing to offer, come back soon."
luti-kriss
throwing myself
an act of my own violation
'98 Black SVT- 3949/6535 8k miles ticked away, Eibach springs, Koni Struts, SHOShop CAI, Ford 9mm racing wires, deleted res., lead foot...more to come.
http://community.webshots.com/user/svtminiflea
I just got the ShoShop intake too and will be adding the BAT "Air inlet pipe" Will have to see how it all works. And that my 2 cents laugh
Chow
1998 SVT #2263 of 6535
chowsvt@msn.com
H
H
will the shoshop heat shield fit other intake setups using non-shoshop maf adapters and filters(k&n)
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Page 2 of 3 1 2 3
