#1190063 02/17/05 05:24 PM
sandman Offline OP
I have the stock gauge display for a 95 GL with the V6. I will eventually replace the gauges for white/indiglo gauges but I also want to replace the temperature gauge with one that has actual numbers on it, not just NORMAL and a red line. Is there a gauge that fits in the factory location that I can swap it with or would I need to put one on the A-pillar? If there's one that I can swap it out in the factory location, can I get it to match. Thank you for your help.
I dont know of any direct replace ments, but i dont think it would be that hard to mod one into place, buy an aftermarket and cut out the old one, some fiberglass and your set.
1996 Contour V6 2.5L 24V 5 speed Shift knob: pilot Nickel Metallic Millennium Plus Series Foglights: Pilot Pictures: http://www.cardomain.com/memberpage/787584
